Canon PowerShot G11 Rear Dial Replacement
  1. Canon PowerShot G11 Rear Dial Replacement, Rear Cover: step 1, image 1 of 1
    • Remove the three screws on the bottom of the camera using the 00 sized phillips head screw driver.
  2. Canon PowerShot G11 Rear Dial Replacement: step 2, image 1 of 1
    • Remove the four screws on the left side of the camera.
  3. Canon PowerShot G11 Rear Dial Replacement: step 3, image 1 of 1
    • Remove the screw on the right side of the camera.
  4. Canon PowerShot G11 Rear Dial Replacement: step 4, image 1 of 1
    • Open up the HDMI port on the right side of the camera. Then remove the screw in the HDMI port.
  5. Canon PowerShot G11 Rear Dial Replacement: step 5, image 1 of 1
    • Remove the screw to the right of the view finder on the rear of the camera.
  6. Canon PowerShot G11 Rear Dial Replacement: step 6, image 1 of 1
    • Use the spudger to crack open the case.
  7. Canon PowerShot G11 Rear Dial Replacement: step 7, image 1 of 1
    Tool used on this step:
    Buy
    • The rear case is still attached to the camera with a ribbon cable. The socket has a flip up lid that must be flipped up before the cable can be removed. Use the tweezers to flip the cable attachment up.
  8. Canon PowerShot G11 Rear Dial Replacement: step 8, image 1 of 1
    • The rear cover is now unattached from the camera.
  9. Canon PowerShot G11 Rear Dial Replacement, Rear Dial: step 9, image 1 of 1
    • Remove the plastic covering of the left side of the rear case interior.
  10. Canon PowerShot G11 Rear Dial Replacement: step 10, image 1 of 1
    • Remove the four screws that are now accessible with the removal of the plastic covering them.
  11. Canon PowerShot G11 Rear Dial Replacement: step 11, image 1 of 2 Canon PowerShot G11 Rear Dial Replacement: step 11, image 2 of 2
    • After the screws are removed, pull the metal bracket out of the camera.
  12. Canon PowerShot G11 Rear Dial Replacement: step 12, image 1 of 1
    • Push the dial out from the other side of the cover.
  13. Canon PowerShot G11 Rear Dial Replacement: step 13, image 1 of 1
    • Remove the dial from the case completely.
2 other people completed this guide.
Dustin Brinegar
688 Reputation
4 Guides authored
USF Tampa, Team 5-6, Brown Winter 2015 Member of USF Tampa, Team 5-6, Brown Winter 2015
USFT-BROWN-W15S5G6
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 19
All Time: 2,184
