Acer Iconia Tab 8 A1-840 Front Camera Replacement
Claire Posadas
Claire Posadas and 4 other contributors
Last updated on May 7, 2024
20 minutes
Moderate
Introduction
Go to step 1
In order to replace the camera you'll have to first remove the back cover. The camera is one of the easiest components to replace once the cover is removed.
Tools
Show more…
  1. Acer Iconia Tab 8 A1-840 Front Camera Replacement, Back Panel: step 1, image 1 of 1
    • Power off the device
    • Remove any cables that might be connected to your device
    • Make sure the device is placed on a flat surface with the display screen facing up
  2. Acer Iconia Tab 8 A1-840 Front Camera Replacement: step 2, image 1 of 1
    • Wedge the plastic opening tool in between the display screen and back panel
    • Do not apply too much pressure in order to avoid cracking the screen
  3. Acer Iconia Tab 8 A1-840 Front Camera Replacement: step 3, image 1 of 1
    • Carefully separate the display from the back panel
  4. Acer Iconia Tab 8 A1-840 Front Camera Replacement, Front Camera: step 4, image 1 of 1
    • Use the spudger to lift the the black flap.
  5. Acer Iconia Tab 8 A1-840 Front Camera Replacement: step 5, image 1 of 1
    Tool used on this step:
    • Use the ESD safe precision tweezers to pull the connector out and carefully remove the camera.
Claire Posadas
396 Reputation
3 Guides authored
UW Tacoma, Team 1-1, Rose Fall 2016 Member of UW Tacoma, Team 1-1, Rose Fall 2016
UWT-ROSE-F16S1G1
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 419
