Canon PowerShot G7X Flash Replacement
  1. Canon PowerShot G7X Flash Replacement, Dial: step 1, image 1 of 1
    • Remove the five 2mm Phillips #000 screws that are under the screen of the camera.
  2. Canon PowerShot G7X Flash Replacement: step 2, image 1 of 1
    • Remove the two 3mm Phillips #000 screws under the AV-out digital flap.
    • Remove the two 3 mm Phillips #000 screws from the side of the camera.
  3. Canon PowerShot G7X Flash Replacement: step 3, image 1 of 1
    • Remove the two 3 mm Phillips #000 screws on the side of camera with the flash toggle.
  4. Canon PowerShot G7X Flash Replacement: step 4, image 1 of 1
    • Remove the four 4 mm Phillips #000 screws from the plate on the bottom of the camera.
  5. Canon PowerShot G7X Flash Replacement: step 5, image 1 of 1
    • Remove the back plate.
  6. Canon PowerShot G7X Flash Replacement: step 6, image 1 of 1
    • Remove the three 3 mm Phillips #000 screws around the dial.
  7. Canon PowerShot G7X Flash Replacement: step 7, image 1 of 2 Canon PowerShot G7X Flash Replacement: step 7, image 2 of 2
    • Using the nylon spudger, gently lift the ZIF tab.
    • Disconnect the ribbon cable that connects the dial to the motherboard.
    • Remove the dial from the device.
  8. Canon PowerShot G7X Flash Replacement, Flash: step 8, image 1 of 2 Canon PowerShot G7X Flash Replacement, Flash: step 8, image 2 of 2
    • Remove the three, blue 5 mm Phillips screws from the back plate.
    • Remove seven 2 mm Phillips #000 screws.
  9. Canon PowerShot G7X Flash Replacement: step 9, image 1 of 2 Canon PowerShot G7X Flash Replacement: step 9, image 2 of 2
    • While using the plastic opening tool, gently pry the top plate off the camera.
  10. Canon PowerShot G7X Flash Replacement: step 10, image 1 of 2 Canon PowerShot G7X Flash Replacement: step 10, image 2 of 2
    • Using the black nylon spudger, gently lift the ribbon cable connected to the LCD screen housing until it comes out then remove the housing.
  11. Canon PowerShot G7X Flash Replacement: step 11, image 1 of 2 Canon PowerShot G7X Flash Replacement: step 11, image 2 of 2
    • Remove the 2 mm Phillips #000 screw underneath the top plate.
    • Remove silver plate.
  12. Canon PowerShot G7X Flash Replacement: step 12, image 1 of 1
    • Take the Phillips #000 and remove the three 5 mm screws from the front plate.
  13. Canon PowerShot G7X Flash Replacement: step 13, image 1 of 2 Canon PowerShot G7X Flash Replacement: step 13, image 2 of 2
    • Using the spudger, gently lift the ribbon cable from underneath the front plate.
    • Remove the front plate.
  14. Canon PowerShot G7X Flash Replacement: step 14, image 1 of 2 Canon PowerShot G7X Flash Replacement: step 14, image 2 of 2
    • Remove flash toggle plate.
    • Remove the 2mm Phillips #000 screws under the flash toggle.
  15. Canon PowerShot G7X Flash Replacement: step 15, image 1 of 2 Canon PowerShot G7X Flash Replacement: step 15, image 2 of 2
    • Flash contains charged capacitor. Shock hazard.
    • Using the black nylon spudger, gently lift the ribbon cable that connects the flash to motherboard and remove the flash from the device.
1 Guide Comment
Hi,
great guide, thanks!. Where can I buy the flash?
Best
david olivelli - Reply
Past 24 Hours: 6
Past 7 Days: 31
Past 30 Days: 141
All Time: 4,226
