Canon PowerShot G9x Lens cap is stuck repair
Introduction
Go to step 1Some times the blades of the built in lens cap get stuck so they do not close or open fully. This can be caused by dirt or by a "blunt force trauma" to the lens housing or blades.
1. switch camera on, lens will extent
2. remove battery so lens will not retract automatically
3. take the front part of the lens and pull gently but firmly. with a little bit of manipulating the housing will slide off. Be carefull to hold the lens pointed upward so the parts of the lens cap will not fall off.
4. The lens cap parts consist out of 3 blades on the top and 3 on the bottom side. The top 2 can be taken off for cleaning. Keep the one with the spring attached in position. the blades on top and bottom are nearly identical. no 3 is with the spring, no2, with big pin, no 1 is with small pin
I have a G9X Mark 2 - There are 2 blades (not 3) above and 2 blades (not 3) below (in reference to the top and bottom of the camera.
The blades closest to the lens are attached with a tiny spring near the pivot post of each. Note that there are two positions to attach the spring on each of the blades. Mine uses the attachment hook nearest the post (the other is not used).
The blades closest to you (that is, away from the lens) are also connected to the same pivot posts, but they do not have a spring. They lie flat on the blade below them.
5. Clean the inside of the lens housing and the blades with some cleaning alkohol. Blow dry 6. clean with canned air the inside of the lens if necessarry,
7. if problem was caused by a dent in the lens housing or blades, put it on a flat hard surface and press with fingers or blut tool from the inside the front of the lens cap in the original form. DO NOT use hammer or plyers.
8. assembled the blades again. no3 is still in place, place no2 with the pin down. the pin slides partly under no 3, then put no 1 on top, pin down. The whole assembly should not stick out.
DO NOT use any lubricant, oil, grease, WD40 or what so ever.
9. Slide the lens housing back over the lens. Watch the position of the printing on the housing so it slides completely in. 10. Ready, put the battery in ! and test.
Alternative if blades are damaged beyond repair, remove all 6 blades and use a plastic lens cap, or order with canon 6 new blades, hope you will get them (for free).
3 other people completed this guide.
4 Comments
Do you have any pictures on how the springs attach to the blades? My camera fell from a tripod while setting up to make a star movie, the impact jogged everything loose. Thank you.
Do you have pictures on how the blades attach to the springs?
When I removed the cover, one of the springs came off. It’s a very tiny thing and you’ll need to use a tweezers to carefully hook it back to the moving blade and the fixed point. This serves as a caution to be very smooth when you remove that cover so as not to jar things. It’s the cover that actually holds all the blades in place so that’s one reason to be careful.
As mentioned: note that the mark 2 is evidently different than the original g9x (or perhaps a change was made in production at some time)
thank you to the original person who posted this. My g9x mark 2 has some differences, (fewer parts) for which I’ve added notes. After disassembling and then reassembling (using alcohol to clean the parts) everything functions perfectly.
Daniel - Reply
Thanks for the instructions, it takes a fair bit of effort to remove the cap, at there are small sections of tape holding it in place. some gentle heat might help the process, i have linked to video and images of the removal process(video and images of removal process) there was a small amount of gunk on the inside of the blades and once removed everything was perfect again.
Frost - Reply
