Canon PowerShot S100 Outer Case Replacement
  1. Canon PowerShot S100 Outer Case Replacement, Outer Case: step 1, image 1 of 3 Canon PowerShot S100 Outer Case Replacement, Outer Case: step 1, image 2 of 3 Canon PowerShot S100 Outer Case Replacement, Outer Case: step 1, image 3 of 3
    • Remove the 2 screws (3.2mm, Phillips #00) found on the bottom side of the camera.
    • Remove the 2 screws (3.2mm, Phillips #00) found on the side of the camera.
    • Remove the 2 screws (3.2mm, Phillips #00) found on the side of the camera where the terminals are.
    • Open the flap revealing the cable inputs and remove the final screw (3.8mm, Phillips #00) found inside.
  2. Canon PowerShot S100 Outer Case Replacement: step 2, image 1 of 1
    • Turn the camera so that the LCD screen is facing you.
    • Remove the back panel by pulling it off of the camera.
  3. Canon PowerShot S100 Outer Case Replacement: step 3, image 1 of 3 Canon PowerShot S100 Outer Case Replacement: step 3, image 2 of 3 Canon PowerShot S100 Outer Case Replacement: step 3, image 3 of 3
    Tool used on this step:
    Buy
    • Turn the camera so that the lens is facing you.
    • Do not pull the front panel off without removing the ribbon cable first.
    • Slowly lift the front panel from the camera.
    • The ribbon cable is connecting the front panel to the camera. Using the tweezers, gently pull the ribbon cable out of its socket.
    • A spudger may also be used to remove the ribbon cable.
    • Remove the rubber guard that rests on top of the lens.
Ricky
968 Reputation
5 Guides authored
USF Tampa, Team 1-4, Leahy Winter 2015 Member of USF Tampa, Team 1-4, Leahy Winter 2015
USFT-LEAHY-W15S1G4
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 10
Past 30 Days: 13
All Time: 1,213
