Introduction
Remove all accessories connected to the camera prior to lens removal out of precaution.
Remove the battery by sliding open the cover on the bottom of the camera.
Removing the following 6 Phillips screws will allow access to the inside of the camera:
Remove two screws on the right-side of the camera, near the HDMI port.
Remove two screws on the opposite side of the camera.
Remove the last two screws on the underside of the camera, near the tripod mounting hole.
To remove the flash assembly, disconnect the flex cable connection, then move the flash unit out of the way.
10 other people completed this guide.
9 Comments
There is a step missing, on removing the flash, one side screw and one front, above the lens, otherwise perfect. thank you so much, just as above I had a lens error and ordered a replacement for 14£ from ebay. all works now. thanks.
Is there no other 'fix' without replacing the lens assembly on this particular "Lens error "issue?
@profeduards: try to reseat the flexes from the aperture and IS. You can disassemble the lens to reset the position and/or remove sand but make lots of pictures of the process, and mark (with pencil) a line over the rings (from the front) to know what ring goes where when reassembling. It's possible to reassemble without (as I did, lens was extended so i couldnt) but the process is long, arduous and takes a lot of patience.
Thanks, my Lens was bricked, and with a new Lens kit @15$ from china, it was fixed.
