Introduction
Remove all accessories connected to the camera prior to lens removal out of precaution.
Remove the battery by sliding open the cover on the bottom of the camera.
Removing the following 6 Phillips screws will allow access to the inside of the camera:
Remove two screws on the right-side of the camera, near the HDMI port.
Remove two screws on the opposite side of the camera.
Remove the last two screws on the underside of the camera, near the tripod mounting hole.
To remove the flash assembly, disconnect the flex cable connection, then move the flash unit out of the way.
Using a prying tool, remove the lens bracket.
This is separating the lens from the sensor so be careful with both. You can disassemble the lens itself but is a Real Puzzle to reassemble. With five rings that have to mesh correctly, not to mention the position of the aperture and the Image Stabilized middle lens, and two flexes that have to be put in their correct locations.
10 other people completed this guide.
9 Comments
There is a step missing, on removing the flash, one side screw and one front, above the lens, otherwise perfect. thank you so much, just as above I had a lens error and ordered a replacement for 14£ from ebay. all works now. thanks.
Is there no other 'fix' without replacing the lens assembly on this particular "Lens error "issue?
@profeduards: try to reseat the flexes from the aperture and IS. You can disassemble the lens to reset the position and/or remove sand but make lots of pictures of the process, and mark (with pencil) a line over the rings (from the front) to know what ring goes where when reassembling. It's possible to reassemble without (as I did, lens was extended so i couldnt) but the process is long, arduous and takes a lot of patience.
Thanks, my Lens was bricked, and with a new Lens kit @15$ from china, it was fixed.
Bought a new lens from ebay, replaced it and it worked for two days. But now, when I hit the ON-button, lens go out, the titlescreen pops up but then all is black. And when I try to turn it off, the lens won´t go back in. There is no message of lens error. I can push the playbutton to get the lens to go back in. And I can also see old pictures so nothing wrong with the LCD. Could the new lens be damaged? Also tried to reset the flexcables several times but the problem remains. Any ideas out there?
Holger, look at Step 7. The 2nd flex cable from the left at the top of the camera—be sure that cable is seated well. I just had my camera apart and the screen was not lighting so I reset a couple of cables and that was the one that brought the screen back. I did a complete tear down following these instructions and put it back together. The lens came out and the lens message came back on. I’m wondering if this might have something to do with the motor. I was thinking that the wheel/gear that is attached to the motor drive should be secured on the spindle. Mine was not. It did manage to drive the lens out once. I’m not sure what kind of motor that is and how it works but I’m thinking the next time I take it apart I might just epoxy that gear onto the end of the spindle (unless someone here tells me not to because it is supposed to be that way). Thanks.
