Canon PowerShot S400 SD Card Slot Replacement
  1. Canon PowerShot S400 SD Card Slot Replacement, SD Card Slot: step 1, image 1 of 2 Canon PowerShot S400 SD Card Slot Replacement, SD Card Slot: step 1, image 2 of 2
    • Unless otherwise stated,a #00 philips screwdriver will be used to remove screws.
    • Remove the 4.75mm screw located in the top right corner of the backside of the camera.
    • Remove the four 4.75mm screws located on the bottom of the camera.
  2. Canon PowerShot S400 SD Card Slot Replacement: step 2, image 1 of 1
    • Remove the two 4.75mm screws located on the right side of the camera.(the side with the USB adaption plug)
  3. Canon PowerShot S400 SD Card Slot Replacement: step 3, image 1 of 3 Canon PowerShot S400 SD Card Slot Replacement: step 3, image 2 of 3 Canon PowerShot S400 SD Card Slot Replacement: step 3, image 3 of 3
    • Remove the four 4.75mm screws on the left side of the camera.
    • This will release two small metal plates. Remove these plate.
  4. Canon PowerShot S400 SD Card Slot Replacement: step 4, image 1 of 1
    • Only remove the back case.
    • The memory card is held in the metal case located to the right of the LCD screen.
    • Remove the stuck memory card.
    • If you still cannot remove the stuck memory card, proceed with further instructions. If you could remove the memory card then you are done
  5. Canon PowerShot S400 SD Card Slot Replacement: step 5, image 1 of 2 Canon PowerShot S400 SD Card Slot Replacement: step 5, image 2 of 2
    • There is a small black plastic piece that sits above the lens underneath the camera case. This plastic piece may fall out when you remove the cases; recover the piece and save it.
    • Separate the front casing from the camera
  6. Canon PowerShot S400 SD Card Slot Replacement: step 6, image 1 of 2 Canon PowerShot S400 SD Card Slot Replacement: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • If the small plastic piece described in the previous step did not fall out, remove it now. The piece is located in a small gap above the lens and to the left of the flash.
    • Removing this piece may require the use of tweezers.
  7. Canon PowerShot S400 SD Card Slot Replacement: step 7, image 1 of 2 Canon PowerShot S400 SD Card Slot Replacement: step 7, image 2 of 2
    • Locate and remove the three 3.45mm screws on the backside of the camera securing the CF card slot.
    • Do not remove ribbon cable. It is not necessary to remove
    • Without removing the ribbon cable, gently remove the memory card.
Adam Grijalva
202 Reputation
2 Guides authored
Cal Poly, Team 5-19, Amido Winter 2011 Member of Cal Poly, Team 5-19, Amido Winter 2011
CPSU-AMIDO-W11S5G19
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 16
All Time: 4,085
