Canon PowerShot S400 Shutter Button Assembly Replacement
  1. Canon PowerShot S400 Shutter Button Assembly Replacement, Shutter Button Assembly: step 1, image 1 of 2 Canon PowerShot S400 Shutter Button Assembly Replacement, Shutter Button Assembly: step 1, image 2 of 2
    • Unless otherwise stated,a #00 philips screwdriver will be used to remove screws.
    • Remove the 4.75mm screw located in the top right corner of the backside of the camera.
    • Remove the four # screws located on the bottom of the camera.
  2. Canon PowerShot S400 Shutter Button Assembly Replacement: step 2, image 1 of 3 Canon PowerShot S400 Shutter Button Assembly Replacement: step 2, image 2 of 3 Canon PowerShot S400 Shutter Button Assembly Replacement: step 2, image 3 of 3
    • Remove the two screws located on the right side of the camera.(the side with the USB adaption plug)
    • Remove the four screws on the left side of the camera.
    • This will release a small metal plate. Remove this plate.
  3. Canon PowerShot S400 Shutter Button Assembly Replacement: step 3, image 1 of 3 Canon PowerShot S400 Shutter Button Assembly Replacement: step 3, image 2 of 3 Canon PowerShot S400 Shutter Button Assembly Replacement: step 3, image 3 of 3
    • There is a small black plastic piece that sits above the lens underneath the camera case. This plastic piece may fall out when you remove the cases; recover the piece and save it.
    • Now separate the front and back camera casings.
  4. Canon PowerShot S400 Shutter Button Assembly Replacement: step 4, image 1 of 1
    • Using a spudger, carefully pry the shutter button assembly from the camera.
    • Install the replacement shutter button assembly.
Ross Bryan
359 Reputation
3 Guides authored
Cal Poly, Team 5-19, Amido Winter 2011 Member of Cal Poly, Team 5-19, Amido Winter 2011
CPSU-AMIDO-W11S5G19
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 2,705
