Introduction
This guide describes how to remove the battery casing for cleaning and to check the connections with the rest of the camera.
Lift off the capture button by wiggling it back and forth while pulling upward.
Be careful not to damage the two clips.
Turn the camera over so that the back is facing you.
Unscrew the three Phillips screws using a #0 Phillips screwdriver.
Lift off the Memory Card casing, sliding the ribbon cable through the camera. Keep pulling until the Memory Card and ribbon cable have been removed from the camera.
Note that the ribbon cable is coming from the external front portion of the camera. Make sure that the ribbon cable will not get caught on anything.
Check the battery terminals for any corrosive material or bad connections.
