Canon PowerShot S500 LCD Replacement
  1. Canon PowerShot S500 LCD Replacement, Front and Rear Casing : step 1, image 1 of 2 Canon PowerShot S500 LCD Replacement, Front and Rear Casing : step 1, image 2 of 2
    • Unscrew five Phillips screws using a #0 Phillips screwdriver.
    • One screw is on upper right corner of the back panel.
    • The other four screws are on the bottom of the camera.
  2. Canon PowerShot S500 LCD Replacement: step 2, image 1 of 1
    • Open the memory card cover by moving the slide switch toward the top end of of the camera.
    • Remove the memory card from the slot.
  3. Canon PowerShot S500 LCD Replacement: step 3, image 1 of 1
    • Remove the rear cover from the rest of the camera.
    • This may require gentle rocking of the case to free it.
  4. Canon PowerShot S500 LCD Replacement: step 4, image 1 of 2 Canon PowerShot S500 LCD Replacement: step 4, image 2 of 2
    • Unscrew the four Phillips screws from the side of the casing and one screw from the bottom using a #0 Phillips screwdriver.
  5. Canon PowerShot S500 LCD Replacement: step 5, image 1 of 1
    • Free the front cover from the rest of the camera.
    • The cover may require gentle rocking to remove.
  6. Canon PowerShot S500 LCD Replacement, LCD: step 6, image 1 of 1
    • Unscrew two Phillips screws above the LCD using a #0 Phillips screwdriver.
  7. Canon PowerShot S500 LCD Replacement: step 7, image 1 of 1
    • Gently separate the top of LCD from the rest of the camera using your thumb.
    • Be careful not pull the LCD too far because of the ribbon cable connection.
    • Place the Spudger in the hole of the electrical ribbon.
    • Gently pull the ribbon down using the Spudger until it is free from the camera but still connected to the LCD.
    • The LCD will still be connected to the rest of the camera
  8. Canon PowerShot S500 LCD Replacement: step 8, image 1 of 2 Canon PowerShot S500 LCD Replacement: step 8, image 2 of 2
    • Unscrew single Phillips screw with a #0 Phillips screwdriver.
    • Free the bottom panel and attached ribbon from the rest of the camera.
    • Be careful not to damage the ribbon.
  9. Canon PowerShot S500 LCD Replacement: step 9, image 1 of 1
    • Turn over the camera.
    • Lift the clear plastic from the face of the camera, peeling the adhesive just below the zoom lens.
    • The plastic will still be connected on the left side.
  10. Canon PowerShot S500 LCD Replacement: step 10, image 1 of 1
    • Place the Spudger between the orange ribbon and the black ribbon gate.
    • Lift the ribbon gate using the Spudger.
  11. Canon PowerShot S500 LCD Replacement: step 11, image 1 of 1
    • Place the Spudger in the corner of the ribbon above the hole.
    • Remove the ribbon from the ribbon gate by pulling the Spudger away from the gate.
  12. Canon PowerShot S500 LCD Replacement: step 12, image 1 of 1
    • Free this ribbon and the bottom panel from the rest of the camera.
  13. Canon PowerShot S500 LCD Replacement: step 13, image 1 of 1
    • Turn the camera over so you can see the LCD.
    • Remove single Phillips screw below the LCD using a #0 Phillips screwdriver.
  14. Canon PowerShot S500 LCD Replacement: step 14, image 1 of 1
    • Lift the blue ribbon gate using the Spudger.
  15. Canon PowerShot S500 LCD Replacement: step 15, image 1 of 1
    • Insert the Spudger into the hole of the ribbon.
    • Move the Spudger away from the gate to fully remove ribbon.
  16. Canon PowerShot S500 LCD Replacement: step 16, image 1 of 1
    • Lift the LCD away from the rest of the camera.
Nathan Balcom
81 Reputation
8 Guides authored
Cal Poly, Team 16-28, Maness Winter 2010 Member of Cal Poly, Team 16-28, Maness Winter 2010
CPSU-MANESS-W10S16G28
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 3,134
