Canon PowerShot S80 Speaker Replacement
  1. Canon PowerShot S80 Speaker Replacement, Outer Casing: step 1, image 1 of 2 Canon PowerShot S80 Speaker Replacement, Outer Casing: step 1, image 2 of 2
    • Remove the knot on the wrist lanyard.
    • Remove the battery and the memory card.
  2. Canon PowerShot S80 Speaker Replacement: step 2, image 1 of 2 Canon PowerShot S80 Speaker Replacement: step 2, image 2 of 2
    • Begin removing the screws on the bottom of the outer casing.
    • Next, remove the rest of the screws from the outer casing.
  3. Canon PowerShot S80 Speaker Replacement: step 3, image 1 of 3 Canon PowerShot S80 Speaker Replacement: step 3, image 2 of 3 Canon PowerShot S80 Speaker Replacement: step 3, image 3 of 3
    • Gently pull the front cover off of the camera.
  4. Canon PowerShot S80 Speaker Replacement: step 4, image 1 of 3 Canon PowerShot S80 Speaker Replacement: step 4, image 2 of 3 Canon PowerShot S80 Speaker Replacement: step 4, image 3 of 3
    • Open the "A/V Out Digital" cover. Remove the screw inside.
    • Gently pull off the back casing.
    • Remove the black "L" shaped piece of metal.
  5. Canon PowerShot S80 Speaker Replacement, Speaker: step 5, image 1 of 1
    • Remove the screw and unplug the wire lead.
    • Gently remove the speaker from the camera body.
BrettH
219 Reputation
5 Guides authored
Cal Poly, Team 19-5, Maness SU 2012 Member of Cal Poly, Team 19-5, Maness SU 2012
CPSU-MANESS-SU12S19G5
1 Member
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 2,022
