Canon PowerShot SD1100 IS Top Button Assembly Replacement
  1. Canon PowerShot SD1100 IS Top Button Assembly Replacement, Front and Rear Cover: step 1, image 1 of 2 Canon PowerShot SD1100 IS Top Button Assembly Replacement, Front and Rear Cover: step 1, image 2 of 2
    • Remove wrist strap and battery.
  2. Canon PowerShot SD1100 IS Top Button Assembly Replacement: step 2, image 1 of 3 Canon PowerShot SD1100 IS Top Button Assembly Replacement: step 2, image 2 of 3 Canon PowerShot SD1100 IS Top Button Assembly Replacement: step 2, image 3 of 3
    • Remove 2 screws from each side of the camera (4 total, 0.102 in).
    • Remove 2 screws from the bottom on the camera (0.138 in).
    • Do not mix the 4 side screws with the 2 bottoms ones; they are different sizes.
  3. Canon PowerShot SD1100 IS Top Button Assembly Replacement: step 3, image 1 of 3 Canon PowerShot SD1100 IS Top Button Assembly Replacement: step 3, image 2 of 3 Canon PowerShot SD1100 IS Top Button Assembly Replacement: step 3, image 3 of 3
    • Gently pull off the front cover.
    • The plate on the side should come off.
    • Gently pull off the back cover.
  4. Canon PowerShot SD1100 IS Top Button Assembly Replacement: step 4, image 1 of 1
    • The cases should now be removed.
  5. Canon PowerShot SD1100 IS Top Button Assembly Replacement, Top Button Assembly: step 5, image 1 of 1
    • Use the spudger to disconnect the black tab.
  6. Canon PowerShot SD1100 IS Top Button Assembly Replacement: step 6, image 1 of 1
    • Gently pull off the shutter button assembly.
  7. Canon PowerShot SD1100 IS Top Button Assembly Replacement: step 7, image 1 of 1
    Tool used on this step:
    Buy
    • Use the tweezers to disconnect the microphone cable.
  8. Canon PowerShot SD1100 IS Top Button Assembly Replacement: step 8, image 1 of 1
    • The shutter button assembly should now be removed.
Wyatt Chan
235 Reputation
2 Guides authored
Cal Poly, Team 3-32, Regan Winter 2011 Member of Cal Poly, Team 3-32, Regan Winter 2011
CPSU-REGAN-W11S3G32
3 Members
8 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 3
All Time: 2,149
