Canon PowerShot SD1200 IS Front and Rear Covers Replacement
  1. Canon PowerShot SD1200 IS Front and Rear Covers Replacement, Front and Rear Covers: step 1, image 1 of 1
    • Remove the battery.
  2. Canon PowerShot SD1200 IS Front and Rear Covers Replacement: step 2, image 1 of 3 Canon PowerShot SD1200 IS Front and Rear Covers Replacement: step 2, image 2 of 3 Canon PowerShot SD1200 IS Front and Rear Covers Replacement: step 2, image 3 of 3
    • Remove the two screws from the side of the camera casing with the strap. (4mm Phillips 00)
    • Remove the two screws from the bottom of the camera. (4mm Phillips 00)
    • Remove the two screws from the right side of the camera opposite the strap. (2mm Phillips 00)
  3. Canon PowerShot SD1200 IS Front and Rear Covers Replacement: step 3, image 1 of 2 Canon PowerShot SD1200 IS Front and Rear Covers Replacement: step 3, image 2 of 2
    • Pull off the front cover.
    • If the top of the cover sticks, use gentle downward pressure on the retention clips above the lens to release.
    • Remove the back cover.
2 other people completed this guide.
Jeff Casper
848 Reputation
7 Guides authored
USF Tampa, Team 17-5, Blackwell Fall 2016 Member of USF Tampa, Team 17-5, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G5
3 Members
7 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 29
All Time: 944
