Canon PowerShot SD1400 IS Motherboard Replacement
  1. Canon PowerShot SD1400 IS Motherboard Replacement, Motherboard: step 1, image 1 of 3 Canon PowerShot SD1400 IS Motherboard Replacement, Motherboard: step 1, image 2 of 3 Canon PowerShot SD1400 IS Motherboard Replacement, Motherboard: step 1, image 3 of 3
    • Remove two 2mm Phillips #00 screws on both sides of the camera.
  2. Canon PowerShot SD1400 IS Motherboard Replacement: step 2, image 1 of 1
    • Remove the 4mm Phillips #000 screw from the bottom.
  3. Canon PowerShot SD1400 IS Motherboard Replacement: step 3, image 1 of 1
    • Remove the front face panel of the camera.
  4. Canon PowerShot SD1400 IS Motherboard Replacement: step 4, image 1 of 1
    • Remove the rear panel of the camera by using hand with firm pressure.
    • The user interface panel, side and bottom panel of the camera may fall down by itself while you are taking the rear panel of the camera.
  5. Canon PowerShot SD1400 IS Motherboard Replacement: step 5, image 1 of 1
    • Remove the 3mm Phillips #000 screw from the top of the camera.
  6. Canon PowerShot SD1400 IS Motherboard Replacement: step 6, image 1 of 3 Canon PowerShot SD1400 IS Motherboard Replacement: step 6, image 2 of 3 Canon PowerShot SD1400 IS Motherboard Replacement: step 6, image 3 of 3
    • Pry the three golden ribbons off the motherboard using a plastic opening tool.
  7. Canon PowerShot SD1400 IS Motherboard Replacement: step 7, image 1 of 3 Canon PowerShot SD1400 IS Motherboard Replacement: step 7, image 2 of 3 Canon PowerShot SD1400 IS Motherboard Replacement: step 7, image 3 of 3
    • Use a plastic opening tool to flip up the retaining flap on the ribbon cable ZIF socket.
    • Once released, the small black tab will point straight away from the front face of the camera and the golden film will no longer be attached to the motherboard.
  8. Canon PowerShot SD1400 IS Motherboard Replacement: step 8, image 1 of 2 Canon PowerShot SD1400 IS Motherboard Replacement: step 8, image 2 of 2
    Tool used on this step:
    Buy
    • Unplug the small chip from the face of the camera using a pair of tweezers.
  9. Canon PowerShot SD1400 IS Motherboard Replacement: step 9, image 1 of 3 Canon PowerShot SD1400 IS Motherboard Replacement: step 9, image 2 of 3 Canon PowerShot SD1400 IS Motherboard Replacement: step 9, image 3 of 3
    • Remove the three 3mm Phillips #000 screws from the motherboard.
  10. Canon PowerShot SD1400 IS Motherboard Replacement: step 10, image 1 of 1
    • Remove the 3mm Phillips #000 screw from the rear face of the camera.
  11. Canon PowerShot SD1400 IS Motherboard Replacement: step 11, image 1 of 1
    • Remove the top panel from the camera.
  12. Canon PowerShot SD1400 IS Motherboard Replacement: step 12, image 1 of 2 Canon PowerShot SD1400 IS Motherboard Replacement: step 12, image 2 of 2
    • Remove the motherboard.
Faris Rezwan
457 Reputation
2 Guides authored
IUPUI, Team S1-G2, Harley Spring 2018 Member of IUPUI, Team S1-G2, Harley Spring 2018
IUPUI-HARLEY-S18S1G2
7 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 28
All Time: 401
