Canon PowerShot SD1400 IS User Interface Panel Replacement
  1. Canon PowerShot SD1400 IS User Interface Panel Replacement, User Interface Panel: step 1, image 1 of 3 Canon PowerShot SD1400 IS User Interface Panel Replacement, User Interface Panel: step 1, image 2 of 3 Canon PowerShot SD1400 IS User Interface Panel Replacement, User Interface Panel: step 1, image 3 of 3
    • Remove the four 2.0 mm Phillips screws of the camera using the J00 bit from the 54-bit Driver Kit. There are two screws on both sides.
  2. Canon PowerShot SD1400 IS User Interface Panel Replacement: step 2, image 1 of 1
    • Remove the 4.0 mm Phillips screw located on the bottom of the camera.
  3. Canon PowerShot SD1400 IS User Interface Panel Replacement: step 3, image 1 of 1
    • Remove the front face panel of the camera by hand using firm pressure.
    • If one point of the face is stuck to the body, check if there is a screw preventing the front face from coming off.
  4. Canon PowerShot SD1400 IS User Interface Panel Replacement: step 4, image 1 of 1
    • Remove the rear panel of the camera by hand using firm pressure.
  5. Canon PowerShot SD1400 IS User Interface Panel Replacement: step 5, image 1 of 1
    • Remove the user interface panel by hand. The panel may fall out on its own, this is normal.
    • Replace the user interface panel by setting it in position.
2 other people completed this guide.
Braxton Beal
702 Reputation
3 Guides authored
Baylor, Team S1-G3, Johnson Spring 2018 Member of Baylor, Team S1-G3, Johnson Spring 2018
BU-JOHNSON-S18S1G3
3 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 279
