Canon PowerShot SD200 Memory Card Replacement
  1. Canon PowerShot SD200 Memory Card Replacement, Memory Card: step 1, image 1 of 3 Canon PowerShot SD200 Memory Card Replacement, Memory Card: step 1, image 2 of 3 Canon PowerShot SD200 Memory Card Replacement, Memory Card: step 1, image 3 of 3
    • Use your fingernail to slide the dark gray tab towards the edge of the camera.
    • Slide the light gray door away from the LCD screen and pull up to open the door.
    • The battery and the memory card slots should now be visible.
  2. Canon PowerShot SD200 Memory Card Replacement: step 2, image 1 of 1
    • Press down on the memory card.
    • Memory card should pop out of place.
    • Pull the memory card straight out of the slot.
    • When putting the memory card back in, orient the memory card in the same direction when pulling out.
James Loy
103 Reputation
7 Guides authored
Cal Poly, Team 5-12, Maness Fall 2010 Member of Cal Poly, Team 5-12, Maness Fall 2010
CPSU-MANESS-F10S5G12
4 Members
9 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 14
All Time: 2,568
