Canon PowerShot SD30 Control Panel Replacement
  1. Canon PowerShot SD30 Control Panel Replacement, Front Cover: step 1, image 1 of 2 Canon PowerShot SD30 Control Panel Replacement, Front Cover: step 1, image 2 of 2
    • Be sure to remove the wrist strap and battery before removing the cover.
    • Remove the two 2mm black screws that are located on the underside of the camera.
    • Remove the two 3mm silver screws from the right side of camera.
  2. Canon PowerShot SD30 Control Panel Replacement: step 2, image 1 of 1
    • Gently remove the front cover.
  3. Canon PowerShot SD30 Control Panel Replacement, Back Cover: step 3, image 1 of 3 Canon PowerShot SD30 Control Panel Replacement, Back Cover: step 3, image 2 of 3 Canon PowerShot SD30 Control Panel Replacement, Back Cover: step 3, image 3 of 3
    • Remove the wrist strap and battery before removing the back cover.
    • Remove the 2mm screw from the back of the camera.
    • Remove two 2mm screws from the bottom of the camera.
    • Remove two 2mm screws the left side of camera.
  4. Canon PowerShot SD30 Control Panel Replacement: step 4, image 1 of 1
    • Gently remove the back cover.
  5. Canon PowerShot SD30 Control Panel Replacement, Control Panel: step 5, image 1 of 3 Canon PowerShot SD30 Control Panel Replacement, Control Panel: step 5, image 2 of 3 Canon PowerShot SD30 Control Panel Replacement, Control Panel: step 5, image 3 of 3
    Tool used on this step:
    Buy
    • Use the tweezers to pull up on the piece of black plastic connected to the ribbon to unhook and remove the ribbon connected to the screen.
    • You also have to pull up on the top part of the control panel because it is connected to the metal by a sticky pad.
  6. Canon PowerShot SD30 Control Panel Replacement: step 6, image 1 of 3 Canon PowerShot SD30 Control Panel Replacement: step 6, image 2 of 3 Canon PowerShot SD30 Control Panel Replacement: step 6, image 3 of 3
    • Turn the camera over to the side with the lens and remove the ribbon on the left side.
    • After removing the ribbon there will be a second ribbon to remove that was hiding underneath the first ribbon.
  7. Canon PowerShot SD30 Control Panel Replacement: step 7, image 1 of 1
    • Lift up the button that connects to the power button of the camera so you can remove the control panel.
  8. Canon PowerShot SD30 Control Panel Replacement: step 8, image 1 of 1
    • Remove the control panel from the camera.
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 15
All Time: 382
