Canon PowerShot SD30 Screen Replacement
  1. Canon PowerShot SD30 Screen Replacement, Front Cover: step 1, image 1 of 2 Canon PowerShot SD30 Screen Replacement, Front Cover: step 1, image 2 of 2
    • Be sure to remove the wrist strap and battery before removing the cover.
    • Remove the two 2mm black screws that are located on the underside of the camera.
    • Remove the two 3mm silver screws from the right side of camera.
  2. Canon PowerShot SD30 Screen Replacement: step 2, image 1 of 1
    • Gently remove the front cover.
  3. Canon PowerShot SD30 Screen Replacement, Back Cover: step 3, image 1 of 3 Canon PowerShot SD30 Screen Replacement, Back Cover: step 3, image 2 of 3 Canon PowerShot SD30 Screen Replacement, Back Cover: step 3, image 3 of 3
    • Remove the wrist strap and battery before removing the back cover.
    • Remove the 2mm screw from the back of the camera.
    • Remove two 2mm screws from the bottom of the camera.
    • Remove two 2mm screws the left side of camera.
  4. Canon PowerShot SD30 Screen Replacement: step 4, image 1 of 1
    • Gently remove the back cover.
  5. Canon PowerShot SD30 Screen Replacement, Screen: step 5, image 1 of 2 Canon PowerShot SD30 Screen Replacement, Screen: step 5, image 2 of 2
    • Remove top button panel by removing the screw located at the top right of the panel.
  6. Canon PowerShot SD30 Screen Replacement: step 6, image 1 of 2 Canon PowerShot SD30 Screen Replacement: step 6, image 2 of 2
    • Remove screws both at the top and the base of the screen to free the screen.
  7. Canon PowerShot SD30 Screen Replacement: step 7, image 1 of 3 Canon PowerShot SD30 Screen Replacement: step 7, image 2 of 3 Canon PowerShot SD30 Screen Replacement: step 7, image 3 of 3
    Tool used on this step:
    Buy
    • Use tweezers to lift the tab that secures the screen wire and remove.
    • You need to do this for both wires.
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 279
