Canon PowerShot SD400 Camera Case Replacement
  1. Canon PowerShot SD400 Camera Case Replacement, Camera Case: step 1, image 1 of 3 Canon PowerShot SD400 Camera Case Replacement, Camera Case: step 1, image 2 of 3 Canon PowerShot SD400 Camera Case Replacement, Camera Case: step 1, image 3 of 3
    • Remove the 6 screws holding the casing in place located on the bottom, left and right sides of the camera using a Phillips Screwdriver.
    • Be sure to save the removed screws to allow for easier reassembly.
  2. Canon PowerShot SD400 Camera Case Replacement: step 2, image 1 of 2 Canon PowerShot SD400 Camera Case Replacement: step 2, image 2 of 2
    • Gently separate the camera casing.
    • Once opened, the strap plate and disk pieces will also separate from the camera.
Yi Huang Ke
51 Reputation
4 Guides authored
James Madison, Team 1-1, Allen Fall 2011 Member of James Madison, Team 1-1, Allen Fall 2011
JMU-ALLEN-F11S1G1
4 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 1,963
