Canon PowerShot SD400 LCD Replacement
  1. Canon PowerShot SD400 LCD Replacement, LCD: step 1, image 1 of 3 Canon PowerShot SD400 LCD Replacement, LCD: step 1, image 2 of 3 Canon PowerShot SD400 LCD Replacement, LCD: step 1, image 3 of 3
    • Locate the 6 screws that you must remove to open the camera housing.
    • There are 2 screws on the bottom and 2 screws on each side
  2. Canon PowerShot SD400 LCD Replacement: step 2, image 1 of 3 Canon PowerShot SD400 LCD Replacement: step 2, image 2 of 3 Canon PowerShot SD400 LCD Replacement: step 2, image 3 of 3
    • Using the screwdriver, carefully remove the exterior screws and set them aside to avoid misplacing them.
  3. Canon PowerShot SD400 LCD Replacement: step 3, image 1 of 2 Canon PowerShot SD400 LCD Replacement: step 3, image 2 of 2
    • Locate the interior screw to the top right of the screen.
    • Remove the screw using the screwdriver.
  4. Canon PowerShot SD400 LCD Replacement: step 4, image 1 of 3 Canon PowerShot SD400 LCD Replacement: step 4, image 2 of 3 Canon PowerShot SD400 LCD Replacement: step 4, image 3 of 3
    • Insert the flat-head screwdriver under the LCD screen into the two clips.
    • Lift the LCD screen.
    • Potential for device damage Lift the screen gently and be careful not to rip the screen off.
2 other people completed this guide.
Yi Huang Ke
51 Reputation
4 Guides authored
James Madison, Team 1-1, Allen Fall 2011 Member of James Madison, Team 1-1, Allen Fall 2011
JMU-ALLEN-F11S1G1
4 Members
4 Guides authored
One Comment
Do you carry a lcd screen for the Powershot sd400?
Jesus Licon - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 47
All Time: 3,116
