Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement
  1. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement, Battery: step 1, image 1 of 1
    • Slide open the battery cover.
    • Push the small orange tab to the side so the battery can be removed.
  2. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: step 2, image 1 of 2 Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: step 2, image 2 of 2
    • Slide the battery out of the battery compartment.
  3. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement, Front and Rear Casing: step 3, image 1 of 2 Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement, Front and Rear Casing: step 3, image 2 of 2
    • Two Phillips screws need to be removed using a #00 Phillips screwdriver. The upper screw is under the USB port cover, which can simply be pulled away gently from the casing. the lower screw is visible on the panel.
    • The screws are different sizes. The .125 inch screw is located under the USB port cover. The 0.85 inch screw goes in the lower hole on the panel.
    • When looking at the back of the camera, these two screws are on the right panel of the camera.
  4. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: step 4, image 1 of 1
    • Remove the right side cover from the camera casing.
  5. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: step 5, image 1 of 1
    • Remove a .07 inch Phillips screw using a #00 Phillips screwdriver.
  6. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: step 6, image 1 of 1
    • Remove two .085 inch Phillips screws from the left side of the camera using a #00 Philips screwdriver.
  7. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: step 7, image 1 of 1
    • Remove the left side cover from the camera.
  8. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: step 8, image 1 of 1
    • Remove three .15 inch Phillips screws from the bottom of the camera using a #00 Phillips screwdriver.
  9. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: step 9, image 1 of 2 Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: step 9, image 2 of 2
    • Once the casing is unscrewed, hold the camera with one side facing down, and lift the opposite face of the casing to open it.
    • Remove the internal camera components and layout out all pieces on a clean surface.
    • The front and back cover may require gentle rocking to remove.
  10. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement, Button Contact Panel: step 10, image 1 of 1
    • Carefully wedge the pry tool under the ribbon in the ribbon gate.
    • Gently remove the ribbon from the ribbon gate by pulling it away from the gate with the pry tool.
    • Be careful not to damage the ribbon.
  11. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: step 11, image 1 of 1
    • Gently press the ribbon back to get access to a Phillips screw behind it.
    • Unscrew two .125 inch long Phillips screws using a #00 Philips screwdriver.
  12. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: step 12, image 1 of 3 Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: step 12, image 2 of 3 Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: step 12, image 3 of 3
    • Remove the ribbon with a pry tool by gently pulling it out of the ribbon gate tab.
    • Pull the button board away from the rest of the camera.
  13. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement, LCD: step 13, image 1 of 1
    • Unscrew one .113 inch Phillips screw using a #00 Phillips screwdriver.
  14. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: step 14, image 1 of 1
    • Lift the LCD screen up and away from the tab that holds it in place on the face of the camera.
    • Be careful, the LCD screen is still connect to the camera by a ribbon cable.
  15. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: step 15, image 1 of 2 Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: step 15, image 2 of 2
    • Gently press the pry tool under the ribbon gate and lift up to free the ribbon connecting the LCD to the circuit board.
    • The LCD can now be completely removed from the camera.
  16. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement, Flash Bulb Assembly: step 16, image 1 of 1
    • Arrange camera so it is facing up towards you.
    • Unscrew one .01 inch Phillips screw using a #00 Phillips screwdriver from the front of the camera.
  17. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: step 17, image 1 of 1
    • Gently remove the indicated ribbon from respective ribbon gates.
  18. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: step 18, image 1 of 1
    • Place spudger under white connector and gently lift it vertically out of its slot.
    • Be careful not to damage wire connector during removal.
  19. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: step 19, image 1 of 1
    • Unscrew three .065 inch Phillips screws using a #00 Phillips screwdriver from the back of the camera.
  20. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: step 20, image 1 of 1
    • Gently pull away flash bulb assembly from the rest of the camera.
    • Be careful not to damage the ribbon on the rest of the camera.
Taylor Shields
846 Reputation
8 Guides authored
Clemson, Team 2-1, Benson Fall 2014 Member of Clemson, Team 2-1, Benson Fall 2014
CLEM-BENSON-F14S2G1
4 Members
9 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 265
