Canon PowerShot SD700 Backlight Replacement
  1. Canon PowerShot SD700 Backlight Replacement, Outside Case: step 1, image 1 of 1
    • Turn off the camera by pressing the power button above the LCD screen.
  2. Canon PowerShot SD700 Backlight Replacement: step 2, image 1 of 1
    • Remove the two, small screws on the bottom of the camera using a Phillip's #00 screwdriver.
  3. Canon PowerShot SD700 Backlight Replacement: step 3, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the two, small screws on the right side of the camera.
  4. Canon PowerShot SD700 Backlight Replacement: step 4, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the screw on the left of the camera under the A/V out Digital label.
  5. Canon PowerShot SD700 Backlight Replacement: step 5, image 1 of 1
    • Use a Phillips #00 screwdriver, remove the screw on the bottom of the camera near the battery and memory card slots.
    • This screw will be longer than the rest of the screws.
  6. Canon PowerShot SD700 Backlight Replacement: step 6, image 1 of 1
    • Remove the front, back, and side casings from the camera and set to the side.
  7. Canon PowerShot SD700 Backlight Replacement, LCD screen: step 7, image 1 of 1
    • Remove the two screws that connect the LCD and backlight to the main body of the camera.
  8. Canon PowerShot SD700 Backlight Replacement: step 8, image 1 of 3 Canon PowerShot SD700 Backlight Replacement: step 8, image 2 of 3 Canon PowerShot SD700 Backlight Replacement: step 8, image 3 of 3
    • Gently pry the LCD and the backlight from the main body of the camera.
    • Gently pry the LCD from the backlight.
    • The thin ribbon cable is for the backlight.
    • The thick ribbon cable is for the LCD screen.
  9. Canon PowerShot SD700 Backlight Replacement: step 9, image 1 of 1
    • Carefully lift the ZIF connector that covers the thick ribbon cable.
    • This ZIF connector is fragile. Use caution when lifting it from its down position.
    • Insert the new LCD and reassemble the camera.
  10. Canon PowerShot SD700 Backlight Replacement, Backlight: step 10, image 1 of 1
    Tool used on this step:
    Buy
    • Unplug the ribbon from the housing on the circuitry.
    • Take the new ribbon and insert it into the housing.
    • Tweezers or a tool with a sharp point can be used.
Emilio Rossi
113 Reputation
3 Guides authored
Cal Poly, Team 9-71, Walters Spring 2011 Member of Cal Poly, Team 9-71, Walters Spring 2011
CPSU-WALTERS-S11S9G71
4 Members
9 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 10
All Time: 1,636
