Canon PowerShot SD700 Outside Case Replacement
  1. Canon PowerShot SD700 Outside Case Replacement, Outside Case: step 1, image 1 of 1
    • Turn off the camera by pressing the power button above the LCD screen.
  2. Canon PowerShot SD700 Outside Case Replacement: step 2, image 1 of 1
    • Remove the two, small screws on the bottom of the camera using a Phillip's #00 screwdriver.
  3. Canon PowerShot SD700 Outside Case Replacement: step 3, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the two, small screws on the right side of the camera.
  4. Canon PowerShot SD700 Outside Case Replacement: step 4, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the screw on the left of the camera under the A/V out Digital label.
  5. Canon PowerShot SD700 Outside Case Replacement: step 5, image 1 of 1
    • Use a Phillips #00 screwdriver, remove the screw on the bottom of the camera near the battery and memory card slots.
    • This screw will be longer than the rest of the screws.
  6. Canon PowerShot SD700 Outside Case Replacement: step 6, image 1 of 1
    • Remove the front, back, and side casings from the camera and set to the side.
To reassemble your device, follow steps 1-6 instructions in reverse order.
3 other people completed this guide.
Emilio Rossi
113 Reputation
3 Guides authored
Cal Poly, Team 9-71, Walters Spring 2011 Member of Cal Poly, Team 9-71, Walters Spring 2011
CPSU-WALTERS-S11S9G71
4 Members
9 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 7
All Time: 1,480
