Canon PowerShot SD780 IS LCD Screen Replacement
Introduction
Go to step 1Use this guide to replace an LCD screen on a Canon PowerShot SD780 IS.
The LCD screen is a monitor that displays photos. When the screen is cracked or broken it can distort or not display the images clearly. If you notice you have difficulty seeing the images on the screen, you should replace the LCD screen.
Before beginning this process, make sure your device is powered off and unplugged from the charger.
Turn the camera off by pressing the power button.
Also, make sure the battery is removed, as to avoid any shock injuries. To remove the battery located at the bottom corner of the camera, slide the panel towards the corner. Push the orange tab upwards and remove the battery.
