Canon PowerShot SD850 IS Battery Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Canon PowerShot SD850 IS Battery Replacement, Battery: step 1, image 1 of 1
    • Identify the battery port on the underside of the camera.
  2. Canon PowerShot SD850 IS Battery Replacement: step 2, image 1 of 2 Canon PowerShot SD850 IS Battery Replacement: step 2, image 2 of 2
    • Using your thumb, slide the port to the right and release.
  3. Canon PowerShot SD850 IS Battery Replacement: step 3, image 1 of 1
    • Remove the battery.
  4. Canon PowerShot SD850 IS Battery Replacement, Battery: step 4, image 1 of 1
    • Verify that your battery is a [Li-ion Battery 3.7/1120mAh] model: NB5L
    • Orient battery with contact points facing away from you.
    • Insert battery into battery port.
  5. Canon PowerShot SD850 IS Battery Replacement: step 5, image 1 of 2 Canon PowerShot SD850 IS Battery Replacement: step 5, image 2 of 2
    • Secure [CARD/BATT. OPEN>] hatch by pressing flat, then sliding left into locking position.
Finish Line
iDeleted
2,101 Reputation
39 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 718
