Canon PowerShot SX160 IS Function Wheel Replacement
  1. Canon PowerShot SX160 IS Function Wheel Replacement, Function Wheel: step 1, image 1 of 3 Canon PowerShot SX160 IS Function Wheel Replacement, Function Wheel: step 1, image 2 of 3 Canon PowerShot SX160 IS Function Wheel Replacement, Function Wheel: step 1, image 3 of 3
    • Unscrew the 2-4.8mm black Phillips head screws from the front of the camera using a #0 Phillips screwdriver.
    • Unscrew the 2-4.8mm black Phillips head screws from the side of the camera using a #0 Phillips screwdriver.
    • Unscrew the 3-4.8mm black Phillips head screws from the bottom of the camera using a #0 Phillips screwdriver.
  2. Canon PowerShot SX160 IS Function Wheel Replacement: step 2, image 1 of 2 Canon PowerShot SX160 IS Function Wheel Replacement: step 2, image 2 of 2
    • Using your hands, gently separate the back panel from the camera.
    • Continue to pull the back panel until it completely detaches from the camera.
  3. Canon PowerShot SX160 IS Function Wheel Replacement: step 3, image 1 of 2 Canon PowerShot SX160 IS Function Wheel Replacement: step 3, image 2 of 2
    • Use a #0 phillips screwdriver to unscrew the 3-3.75mm silver Phillips head screws from the function wheel panel of the camera.
  4. Canon PowerShot SX160 IS Function Wheel Replacement: step 4, image 1 of 1
    • Remove and replace the function wheel.
Congratulations, you have successfully replaced your function wheel. To reassemble your device, follow these instructions in reverse order.
Jamie Secretan
1,962 Reputation
6 Guides authored
One Comment
Hi, I replaced the LCD screen but now my function wheel and panel don’t work. I think the ribbon got disconnected , but I can’t figure out where to attach it. Can you help?
Denise Domian - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 14
All Time: 589
