Canon PowerShot SX160 IS Outer Case Replacement
  1. Canon PowerShot SX160 IS Outer Case Replacement, Outer Case: step 1, image 1 of 3 Canon PowerShot SX160 IS Outer Case Replacement, Outer Case: step 1, image 2 of 3 Canon PowerShot SX160 IS Outer Case Replacement, Outer Case: step 1, image 3 of 3
    • Unscrew 2-4.8mm black screws from the front of the camera using a #0 Phillips screwdriver.
    • Unscrew 2-4.8mm black screws from the side of the camera using a #0 Phillips screwdriver.
    • Unscrew 2-4.8mm black screws from the bottom of the camera using a #0 Phillips screwdriver.
  2. Canon PowerShot SX160 IS Outer Case Replacement: step 2, image 1 of 2 Canon PowerShot SX160 IS Outer Case Replacement: step 2, image 2 of 2
    • Using your hands, gently separate the back panel from the camera.
    • Continue to pull the back panel until it completely detaches from the camera.
  3. Canon PowerShot SX160 IS Outer Case Replacement: step 3, image 1 of 2 Canon PowerShot SX160 IS Outer Case Replacement: step 3, image 2 of 2
    • Use your hands to gently separate the front panel from the camera.
    • Continue to pull the front panel until it completely detaches from the camera.
2 other people completed this guide.
Jamie Secretan
1,962 Reputation
6 Guides authored
One Comment
guide is missing removal of several screws. Four silver screws for front cover. I removed a total of 12 screws to remove covers. Guide only shows 6. Also requires disconnection of flex strip attached to front cover, from below wheel
Stewie Wewie - Reply
Past 24 Hours: 3
Past 7 Days: 7
Past 30 Days: 25
All Time: 1,841
