Canon PowerShot SX520 HS Back Face Replacement
  1. Canon PowerShot SX520 HS Back Face Replacement, Battery: step 1, image 1 of 1
    • Using your fingers, slide the battery compartment door to the right until it unlocks.
  2. Canon PowerShot SX520 HS Back Face Replacement: step 2, image 1 of 1
    • Rotate the door along hinges to open.
    • Take out the battery with your fingers.
  3. Canon PowerShot SX520 HS Back Face Replacement, Back Face: step 3, image 1 of 3 Canon PowerShot SX520 HS Back Face Replacement, Back Face: step 3, image 2 of 3 Canon PowerShot SX520 HS Back Face Replacement, Back Face: step 3, image 3 of 3
    • Remove 2-3.4 mm screws that secure the back panel using a Phillips #000 screwdriver.
    • Remove 4-4 mm screws on the left and right sides of the camera using a Phillips #000 screwdriver.
  4. Canon PowerShot SX520 HS Back Face Replacement: step 4, image 1 of 1
    • Remove 2-4 mm screws that secure the bottom of the camera using a Phillips #000 screwdriver.
  5. Canon PowerShot SX520 HS Back Face Replacement: step 5, image 1 of 2 Canon PowerShot SX520 HS Back Face Replacement: step 5, image 2 of 2
    • Pull back the rubber facing to access the A/V and HDMI output compartment.
    • Remove 1-3.4mm screw inside the compartment using a Phillips #000 screwdriver.
  6. Canon PowerShot SX520 HS Back Face Replacement: step 6, image 1 of 1
    • Once all screws are removed, pull the back facing off with your fingers.
Kyle Crowley
337 Reputation
3 Guides authored
Baylor, Team 4-4, Williams Fall 2015 Member of Baylor, Team 4-4, Williams Fall 2015
BU-WILLIAMS-F15S4G4
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 467
