Canon PowerShot SX520 HS LCD Screen Replacement
  1. Canon PowerShot SX520 HS LCD Screen Replacement, Battery: step 1, image 1 of 1
    • Using your fingers, slide the battery compartment door to the right until it unlocks.
  2. Canon PowerShot SX520 HS LCD Screen Replacement: step 2, image 1 of 1
    • Rotate the door along hinges to open.
    • Take out the battery with your fingers.
  3. Canon PowerShot SX520 HS LCD Screen Replacement, Back Face: step 3, image 1 of 3 Canon PowerShot SX520 HS LCD Screen Replacement, Back Face: step 3, image 2 of 3 Canon PowerShot SX520 HS LCD Screen Replacement, Back Face: step 3, image 3 of 3
    • Remove 2-3.4 mm screws that secure the back panel using a Phillips #000 screwdriver.
    • Remove 4-4 mm screws on the left and right sides of the camera using a Phillips #000 screwdriver.
  4. Canon PowerShot SX520 HS LCD Screen Replacement: step 4, image 1 of 1
    • Remove 2-4 mm screws that secure the bottom of the camera using a Phillips #000 screwdriver.
  5. Canon PowerShot SX520 HS LCD Screen Replacement: step 5, image 1 of 2 Canon PowerShot SX520 HS LCD Screen Replacement: step 5, image 2 of 2
    • Pull back the rubber facing to access the A/V and HDMI output compartment.
    • Remove 1-3.4mm screw inside the compartment using a Phillips #000 screwdriver.
  6. Canon PowerShot SX520 HS LCD Screen Replacement: step 6, image 1 of 1
    • Once all screws are removed, pull the back facing off with your fingers.
  7. Canon PowerShot SX520 HS LCD Screen Replacement, LCD Screen: step 7, image 1 of 1
    • Remove 3-4.4 mm screws that secure the small metal plate using a Phillips #000 screwdriver.
  8. Canon PowerShot SX520 HS LCD Screen Replacement: step 8, image 1 of 1
    • Carefully pop out the LCD screen with your fingers.
Lisa Choe
460 Reputation
3 Guides authored
Baylor, Team 4-4, Williams Fall 2015 Member of Baylor, Team 4-4, Williams Fall 2015
BU-WILLIAMS-F15S4G4
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 967
