Canon PowerShot SX520 HS Lens Replacement
  1. Canon PowerShot SX520 HS Lens Replacement, Battery: step 1, image 1 of 1
    • Using your fingers, slide the battery compartment door to the right until it unlocks.
  2. Canon PowerShot SX520 HS Lens Replacement: step 2, image 1 of 1
    • Rotate the door along hinges to open.
    • Take out the battery with your fingers.
  3. Canon PowerShot SX520 HS Lens Replacement, Back Face: step 3, image 1 of 3 Canon PowerShot SX520 HS Lens Replacement, Back Face: step 3, image 2 of 3 Canon PowerShot SX520 HS Lens Replacement, Back Face: step 3, image 3 of 3
    • Remove 2-3.4 mm screws that secure the back panel using a Phillips #000 screwdriver.
    • Remove 4-4 mm screws on the left and right sides of the camera using a Phillips #000 screwdriver.
  4. Canon PowerShot SX520 HS Lens Replacement: step 4, image 1 of 1
    • Remove 2-4 mm screws that secure the bottom of the camera using a Phillips #000 screwdriver.
  5. Canon PowerShot SX520 HS Lens Replacement: step 5, image 1 of 2 Canon PowerShot SX520 HS Lens Replacement: step 5, image 2 of 2
    • Pull back the rubber facing to access the A/V and HDMI output compartment.
    • Remove 1-3.4mm screw inside the compartment using a Phillips #000 screwdriver.
  6. Canon PowerShot SX520 HS Lens Replacement: step 6, image 1 of 1
    • Once all screws are removed, pull the back facing off with your fingers.
  7. Canon PowerShot SX520 HS Lens Replacement, LCD Screen: step 7, image 1 of 1
    • Remove 3-4.4 mm screws that secure the small metal plate using a Phillips #000 screwdriver.
  8. Canon PowerShot SX520 HS Lens Replacement: step 8, image 1 of 1
    • Carefully pop out the LCD screen with your fingers.
  9. Canon PowerShot SX520 HS Lens Replacement, Metal Plate: step 9, image 1 of 3 Canon PowerShot SX520 HS Lens Replacement, Metal Plate: step 9, image 2 of 3 Canon PowerShot SX520 HS Lens Replacement, Metal Plate: step 9, image 3 of 3
    • Remove 6-4.4 mm screws that secure the metal cover using a Phillips #000 screwdriver.
    • Remove 2-2.5 mm screws that secure the back panel using a Phillips #000 screwdriver.
    • After all 8 screws are removed, pull the metal plate out with your fingers.
  10. Canon PowerShot SX520 HS Lens Replacement, Lens: step 10, image 1 of 1
    • Unlcip the large cable by pulling up on the metal part with your finger.
    • Slide out the 2 smaller cables with your fingers.
  11. Canon PowerShot SX520 HS Lens Replacement: step 11, image 1 of 1
    • Lift up the lens by grabbing the sides with your fingers.
6 other people completed this guide.
Lisa Choe
460 Reputation
3 Guides authored
Baylor, Team 4-4, Williams Fall 2015 Member of Baylor, Team 4-4, Williams Fall 2015
BU-WILLIAMS-F15S4G4
4 Members
6 Guides authored
1 Guide Comment
guide is unfinished; dropping to the point of lens group extraction without going on further. I found it, useless.
SimoneGallina - Reply Share
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 24
All Time: 3,588
