Canon PowerShot SX60 HS Back Panel Replacement
  1. Canon PowerShot SX60 HS Back Panel Replacement, Back Panel: step 1, image 1 of 1
    • Make sure to power off the device before completing any more steps.
    • Remove the battery by releasing the orange clip in the battery compartment.
  2. Canon PowerShot SX60 HS Back Panel Replacement: step 2, image 1 of 2 Canon PowerShot SX60 HS Back Panel Replacement: step 2, image 2 of 2
    • Remove the rubber eye piece by pulling it back.
    • Use the Phillips #00 screwdriver to remove the two 5mm #00 screws located on the side of the viewfinder.
  3. Canon PowerShot SX60 HS Back Panel Replacement: step 3, image 1 of 2 Canon PowerShot SX60 HS Back Panel Replacement: step 3, image 2 of 2
    • Use the Phillips #00 screwdriver to remove the 4mm #00 screw located on the bottom left of the device.
    • Use the Phillips #00 screwdriver to remove the 5mm #00 screw located on the bottom center of the device.
    • Use the Phillips #00 screwdriver to remove the 7mm #00 screw on the right top corner of the camera, just above the media ports.
    • Use the Phillips #00 screwdriver to remove the two 5mm #00 screws located on the right side, under the media port dust cover.
  4. Canon PowerShot SX60 HS Back Panel Replacement: step 4, image 1 of 2 Canon PowerShot SX60 HS Back Panel Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Ensure the LCD screen is swung fully to the left before taking off the back panel.
    • Use the iFixit opening tool to pry off the back panel.
    • Don't completely pull off the back panel because there is still a ribbon attached.
    • Use the black spudger to unclip the ribbon located behind the battery compartment. Then remove it using the nylon tipped tweezers.
    • Once the ribbon is unplugged, remove the back panel from the camera body.
0 Comments
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 21
All Time: 790
