Canon Powershot A3300 IS Back Cover Replacement
Phillip Chen
Phillip Chen and 6 other contributors
Last updated on March 7, 2020
5 minutes
Moderate
Introduction
Go to step 1
If you have broken the back cover to your camera or it is worn out this guide will show you how to replace it.
  1. Canon Powershot A3300 IS Back Cover Replacement, Back Cover: step 1, image 1 of 3 Canon Powershot A3300 IS Back Cover Replacement, Back Cover: step 1, image 2 of 3 Canon Powershot A3300 IS Back Cover Replacement, Back Cover: step 1, image 3 of 3
    • Remove four 2.7 mm screws, two on each side, from the camera with a JIS 000 screwdriver.
    • Remove one 3.5 mm screw on the bottom of the camera with a JIS 000 screwdriver.
    • When removing the front and back housings, be careful to not break the tabs that hook into the top section of the chassis.
  2. Canon Powershot A3300 IS Back Cover Replacement: step 2, image 1 of 2 Canon Powershot A3300 IS Back Cover Replacement: step 2, image 2 of 2
    • Pull off the back cover.
2 other people completed this guide.
Phillip Chen
440 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 298
