Canon Powershot A3300 IS Front Cover Replacement
Phillip Chen
Phillip Chen and 2 other contributors
Last updated on March 7, 2020
5 minutes
Moderate
Introduction
Go to step 1
This guide will show you how to replace the front cover of your camera if it is broken or worn.
  1. Canon Powershot A3300 IS Front Cover Replacement, Back Cover: step 1, image 1 of 3 Canon Powershot A3300 IS Front Cover Replacement, Back Cover: step 1, image 2 of 3 Canon Powershot A3300 IS Front Cover Replacement, Back Cover: step 1, image 3 of 3
    • Remove four 2.7 mm screws, two on each side, from the camera with a JIS 000 screwdriver.
    • Remove one 3.5 mm screw on the bottom of the camera with a JIS 000 screwdriver.
    • When removing the front and back housings, be careful to not break the tabs that hook into the top section of the chassis.
  2. Canon Powershot A3300 IS Front Cover Replacement: step 2, image 1 of 2 Canon Powershot A3300 IS Front Cover Replacement: step 2, image 2 of 2
    • Pull off the back cover.
  3. Canon Powershot A3300 IS Front Cover Replacement, Front Cover: step 3, image 1 of 2 Canon Powershot A3300 IS Front Cover Replacement, Front Cover: step 3, image 2 of 2
    • Pull the front cover off.
Phillip Chen
440 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 365
