Canon Powershot A610 Camera Housing Replacement
Matthew Ramirez
Matthew Ramirez and 11 other contributors
Last updated on May 29, 2024
25 - 40 minutes
Moderate
Introduction
Go to step 1
This guide demonstrates how to replace the housing of a Canon Powershot A610. In order to get to the internals of the Canon A610, the plastic casing around the camera must be removed.
Tools
  1. Canon Powershot A610 Camera Housing Replacement, Batteries: step 1, image 1 of 2 Canon Powershot A610 Camera Housing Replacement, Batteries: step 1, image 2 of 2
    • Unlock the battery cover, while swinging the cover outward to open it.
  2. Canon Powershot A610 Camera Housing Replacement: step 2, image 1 of 1
    • Turn the camera over and allow the batteries to fall out.
    • Close the battery cover.
  3. Canon Powershot A610 Camera Housing Replacement, Camera Housing: step 3, image 1 of 3 Canon Powershot A610 Camera Housing Replacement, Camera Housing: step 3, image 2 of 3 Canon Powershot A610 Camera Housing Replacement, Camera Housing: step 3, image 3 of 3
    • Remove the three 3 mm screws that attach the side panel to the body of the camera.
    • Using your fingernails, pull the side panel outward to remove it.
    • Remove the two remaining 2 mm screws that attach to the frame of the camera.
  4. Canon Powershot A610 Camera Housing Replacement: step 4, image 1 of 1
    • Remove the 3 mm screw that sits at the bottom of the camera, near the front side.
    • Remove the 4 mm screw that sits at the bottom of the camera, near the back side.
  5. Canon Powershot A610 Camera Housing Replacement: step 5, image 1 of 1
    • Open the battery cover.
    • Remove the 5 mm screw that sits on the top of the battery slot.
    • Remove the three 6 mm screws that sit at the bottom of the battery slot.
  6. Canon Powershot A610 Camera Housing Replacement: step 6, image 1 of 2 Canon Powershot A610 Camera Housing Replacement: step 6, image 2 of 2
    • Open the digital A/V DC terminal cover.
    • Remove the three 4 mm screws.
    • Detach the digital A/V DC terminal.
    • When you reassemble the camera, leave the topmost screw out until after you put the top casing back.
  7. Canon Powershot A610 Camera Housing Replacement: step 7, image 1 of 1
    • Grip the sides of the top cover and gently lift it until it detaches from the camera.
    • Do not completely remove the top cover; an orange ribbon cable still connects it to the camera.
  8. Canon Powershot A610 Camera Housing Replacement: step 8, image 1 of 2 Canon Powershot A610 Camera Housing Replacement: step 8, image 2 of 2
    • With the camera upside down, pull the side of the front case that is closest to you, in an outward movement.
    • Apply some force, but pull the front case gently to prevent damage.
  9. Canon Powershot A610 Camera Housing Replacement: step 9, image 1 of 2 Canon Powershot A610 Camera Housing Replacement: step 9, image 2 of 2
    • Open the memory card slot cover.
    • Remove the 3 mm screw that sits near the bottom of the case.
  10. Canon Powershot A610 Camera Housing Replacement: step 10, image 1 of 3 Canon Powershot A610 Camera Housing Replacement: step 10, image 2 of 3 Canon Powershot A610 Camera Housing Replacement: step 10, image 3 of 3
    • Flip the LCD screen all the way open.
    • Grip both sides of top of the back case and gently pull it, in an outward movement, until the case detaches.
3 other people completed this guide.
Matthew Ramirez
625 Reputation
5 Guides authored
Cal Poly, Team 11-26, Maness Winter 2011 Member of Cal Poly, Team 11-26, Maness Winter 2011
CPSU-MANESS-W11S11G26
3 Members
9 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 20
All Time: 9,292
