Canon Powershot A70 Rear Exterior Panel Replacement
  1. Canon Powershot A70 Rear Exterior Panel Replacement, Rear Exterior Panel: step 1, image 1 of 1
    • Unscrew the three small screws on the bottom of the camera with a Phillips #00 screwdriver.
    • Remove the wrist strap.
  2. Canon Powershot A70 Rear Exterior Panel Replacement: step 2, image 1 of 1
    • Remove the screw in the CF compartment with a Phillips #00 screwdriver.
  3. Canon Powershot A70 Rear Exterior Panel Replacement: step 3, image 1 of 3 Canon Powershot A70 Rear Exterior Panel Replacement: step 3, image 2 of 3 Canon Powershot A70 Rear Exterior Panel Replacement: step 3, image 3 of 3
    • Open the rubber Digital AV Out compartment flap.
    • Pry the battery with an opening tool.
    • Carefully pull out the battery with two fingers.
    • Remove the two screws that are now visible with a Phillips #00 screwdriver.
  4. Canon Powershot A70 Rear Exterior Panel Replacement: step 4, image 1 of 2 Canon Powershot A70 Rear Exterior Panel Replacement: step 4, image 2 of 2
    • Starting from the bottom, carefully pull the casing off.
    • The casing will now pivot at the top.
    • There are three catches that hold the back casing to the body.
    • You may have to pull with some force. The rear panel will make a snapping noise when it separates from the body.
  5. Canon Powershot A70 Rear Exterior Panel Replacement: step 5, image 1 of 1
    • The interior of the camera should look like this.
Shalan Ertis
83 Reputation
3 Guides authored
Cal Poly, Team 14-40, Regan Winter 2010 Member of Cal Poly, Team 14-40, Regan Winter 2010
CPSU-REGAN-W10S14G40
5 Members
16 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 3
All Time: 3,290
