Canon Powershot S200 Motherboard Replacement
  1. Canon Powershot S200 Motherboard Replacement, Battery: step 1, image 1 of 2 Canon Powershot S200 Motherboard Replacement, Battery: step 1, image 2 of 2
    • Slide the grey latch to open the battery compartment.
  2. Canon Powershot S200 Motherboard Replacement: step 2, image 1 of 2 Canon Powershot S200 Motherboard Replacement: step 2, image 2 of 2
    • Push and slide the orange retaining clip to the right to remove the battery.
  3. Canon Powershot S200 Motherboard Replacement: step 3, image 1 of 1
    • Remove battery from the camera.
  4. Canon Powershot S200 Motherboard Replacement, Motherboard: step 4, image 1 of 1
    • Remove the lanyard.
  5. Canon Powershot S200 Motherboard Replacement: step 5, image 1 of 1
    • Position the camera so that the bottom is facing up.
    • Remove the two 2.3mm screws beneath the name plate.
    • Remove the two 2.8 mm screws surrounding the threaded tripod mount.
  6. Canon Powershot S200 Motherboard Replacement: step 6, image 1 of 1
    • Remove the 3.8mm screw from the back face of the camera.
  7. Canon Powershot S200 Motherboard Replacement: step 7, image 1 of 1
    • Remove the two 2.3mm screws from the right face of the camera.
  8. Canon Powershot S200 Motherboard Replacement: step 8, image 1 of 1
    • Remove the two outer 3.2mm screws from the left side of the camera
    • Remove the two inner 3.7mm screws from the left side of the camera.
  9. Canon Powershot S200 Motherboard Replacement: step 9, image 1 of 1
    • Pull the back face panel away from the front end of the body. This may take some wiggling and force.
  10. Canon Powershot S200 Motherboard Replacement: step 10, image 1 of 2 Canon Powershot S200 Motherboard Replacement: step 10, image 2 of 2
    • Remove the CF card door from the left side of the camera body.
  11. Canon Powershot S200 Motherboard Replacement: step 11, image 1 of 2 Canon Powershot S200 Motherboard Replacement: step 11, image 2 of 2
    • Slide the rubber digital a/v cap out of place on the front plate.
  12. Canon Powershot S200 Motherboard Replacement: step 12, image 1 of 1
    • Remove the front face by sliding it off.
  13. Canon Powershot S200 Motherboard Replacement: step 13, image 1 of 1
    • Remove the rubber seal that covers the right side of the viewfinder.
  14. Canon Powershot S200 Motherboard Replacement: step 14, image 1 of 1
    • Remove the two 3.9mm screws that hold the laminated copper sheet.
  15. Canon Powershot S200 Motherboard Replacement: step 15, image 1 of 2 Canon Powershot S200 Motherboard Replacement: step 15, image 2 of 2
    • Remove the wire connections that connect along the bottom of the motherboard.
  16. Canon Powershot S200 Motherboard Replacement: step 16, image 1 of 1
    • Remove the single 3.8mm screw that is on the motherboard.
  17. Canon Powershot S200 Motherboard Replacement: step 17, image 1 of 1
    • Remove the motherboard from the main frame of the camera body.
Orlando Zuniga
11 Reputation
1 Guide authored
Cal Poly, Team 20-70, Walters Spring 2011 Member of Cal Poly, Team 20-70, Walters Spring 2011
CPSU-WALTERS-S11S20G70
5 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 1,908
