Canon SX40 HS Camera Battery Door Contact Replacement
  1. Canon SX40 HS Camera Battery Door Contact Replacement, Battery Door Contact: step 1, image 1 of 1
    • Orient the camera so that the bottom of the camera is facing up and open the battery compartment.
  2. Canon SX40 HS Camera Battery Door Contact Replacement: step 2, image 1 of 1
    • Remove the two circled 2mm screws with a Phillips #00 screwdriver.
  3. Canon SX40 HS Camera Battery Door Contact Replacement: step 3, image 1 of 1
    • Slide the metal battery contact away from the battery compartment cover.
  4. Canon SX40 HS Camera Battery Door Contact Replacement: step 4, image 1 of 1
    • Remove the battery compartment cover from the metal bracket.
  5. Canon SX40 HS Camera Battery Door Contact Replacement: step 5, image 1 of 1
    • Replace either the internal metal battery contact or external battery compartment cover.
John Bui
352 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 16
All Time: 836
