Canon SX40 HS camera Flash Cover Replacement
  1. Canon SX40 HS camera Flash Cover Replacement, Flash Cover: step 1, image 1 of 2 Canon SX40 HS camera Flash Cover Replacement, Flash Cover: step 1, image 2 of 2
    • Extend the flash cover upwards and remove the 4 mm black screw located on the left side. You will need a Phillips #00 screwdriver to remove it.
    • Repeat to remove the 4 mm black screw located on the right side.
  2. Canon SX40 HS camera Flash Cover Replacement: step 2, image 1 of 1
    • Remove the plastic cover using the iFixIt Plastic Opening Tool.
    • The plastic cover can only be removed in the down position.
  3. Canon SX40 HS camera Flash Cover Replacement: step 3, image 1 of 2 Canon SX40 HS camera Flash Cover Replacement: step 3, image 2 of 2
    • After removing the flash cover, remove the 6 mm silver screw on the right side with a Phillips #00 screwdriver.
    • Repeat to remove the 6 mm silver screw on the left side with a Phillips #00 screwdriver.
  4. Canon SX40 HS camera Flash Cover Replacement: step 4, image 1 of 1
    • Replace the external flash cover or the internal flashlight when all 6 mm silver screws are out.
To reassemble your device, follow Steps 1-4 in reverse order.
John Bui
352 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 824
