Canon SX40 HS camera LCD Screen Cover Replacement
  1. Canon SX40 HS camera LCD Screen Cover Replacement, LCD Screen Cover: step 1, image 1 of 2 Canon SX40 HS camera LCD Screen Cover Replacement, LCD Screen Cover: step 1, image 2 of 2
    • Open/turn the LCD screen until it fully extends outwards.
    • Remove these two 4 mm black screws on the left side of the screen with a Phillips size #00 screwdriver.
  2. Canon SX40 HS camera LCD Screen Cover Replacement: step 2, image 1 of 1
    • Partially close the screen and rotate it 90 degrees until the screen is facing upwards (photo view from the left front of the camera). Remove the 4mm black screw, indicated in the picture, with a Phillips #00 screwdriver.
  3. Canon SX40 HS camera LCD Screen Cover Replacement: step 3, image 1 of 1
    • Rotate the screen 180 degrees until the monitor is facing downwards. Remove the 4mm black screw, indicated in the picture, with a Phillips #00 screwdriver.
  4. Canon SX40 HS camera LCD Screen Cover Replacement: step 4, image 1 of 3 Canon SX40 HS camera LCD Screen Cover Replacement: step 4, image 2 of 3 Canon SX40 HS camera LCD Screen Cover Replacement: step 4, image 3 of 3
    • Using a plastic opening tool, remove the unfastened LCD screen cover from the camera.
    • Be careful not to pry and damage the circuit card under the screen cover.
  5. Canon SX40 HS camera LCD Screen Cover Replacement: step 5, image 1 of 3 Canon SX40 HS camera LCD Screen Cover Replacement: step 5, image 2 of 3 Canon SX40 HS camera LCD Screen Cover Replacement: step 5, image 3 of 3
    • This is what you should see after removing the LCD screen cover. Replace the LCD screen cover if damaged.
2 other people completed this guide.
John Bui
352 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 18
All Time: 1,732
