Canon Selphy CP1200 LCD/Buttons Replacement
  1. Canon Selphy CP1200 LCD/Buttons Replacement, LCD/Buttons: step 1, image 1 of 1
    • Unscrew the four 6mm PH000 corner screws.
    • This will require a screwdriver with a long, narrow shaft.
  2. Canon Selphy CP1200 LCD/Buttons Replacement: step 2, image 1 of 1
    • Unscrew the three 4mm PH1 screws on the bottom of the printer.
  3. Canon Selphy CP1200 LCD/Buttons Replacement: step 3, image 1 of 1
    • Gently pry open the top of the case from either the front or back.
    • A plastic opening tool may help.
    • Be careful in lifting the top assembly as it is attached to the motherboard at this point.
  4. Canon Selphy CP1200 LCD/Buttons Replacement: step 4, image 1 of 1
    Tool used on this step:
    Buy
    • Keeping the top assembly elevated, detach the ribbon cables connecting the LCD and buttons to the motherboard from the motherboard.
    • Tweezers may be useful given the limited space between the top assembly and motherboard.
    • The top assembly, containing both the LCD and buttons, will now be completely free
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 438
