Canon Selphy CP910 Buttons Replacement
  1. Canon Selphy CP910 Buttons Replacement, Body: step 1, image 1 of 2 Canon Selphy CP910 Buttons Replacement, Body: step 1, image 2 of 2
    • Turn the printer over.
    • Use the PH1 screw bit to remove the three 8 mm screws in the middle of the back plate.
    • Keep track of these screws because you will need them to reassemble the printer.
  2. Canon Selphy CP910 Buttons Replacement: step 2, image 1 of 3 Canon Selphy CP910 Buttons Replacement: step 2, image 2 of 3 Canon Selphy CP910 Buttons Replacement: step 2, image 3 of 3
    • Loosen up the four 10 mm corner screws.
    • A screwdriver with a long shaft approximately 7mm in diameter will make it easier to reach these screws.
  3. Canon Selphy CP910 Buttons Replacement: step 3, image 1 of 3 Canon Selphy CP910 Buttons Replacement: step 3, image 2 of 3 Canon Selphy CP910 Buttons Replacement: step 3, image 3 of 3
    • Turn the device around and remove the "open" lid.
    • This lid needs to be removed in order to take the printer apart.
    • Gently bend the lid and remove it from its hinges.
  4. Canon Selphy CP910 Buttons Replacement: step 4, image 1 of 3 Canon Selphy CP910 Buttons Replacement: step 4, image 2 of 3 Canon Selphy CP910 Buttons Replacement: step 4, image 3 of 3
    • Turn the device back over and lift the top panel up.
    • Disconnect the ribbon cables leading to the LCD screen.
    • Pull the top panel off.
  5. Canon Selphy CP910 Buttons Replacement, Buttons: step 5, image 1 of 2 Canon Selphy CP910 Buttons Replacement, Buttons: step 5, image 2 of 2
    • Turn the top panel over so the inside faces toward you.
  6. Canon Selphy CP910 Buttons Replacement: step 6, image 1 of 3 Canon Selphy CP910 Buttons Replacement: step 6, image 2 of 3 Canon Selphy CP910 Buttons Replacement: step 6, image 3 of 3
    • Use the PH0 screw bit to remove the five 10 mm screws located above the circuit board.
  7. Canon Selphy CP910 Buttons Replacement: step 7, image 1 of 2 Canon Selphy CP910 Buttons Replacement: step 7, image 2 of 2
    • Carefully remove the frame attached to the screen.
  8. Canon Selphy CP910 Buttons Replacement: step 8, image 1 of 3 Canon Selphy CP910 Buttons Replacement: step 8, image 2 of 3 Canon Selphy CP910 Buttons Replacement: step 8, image 3 of 3
    • Take out the circuit board.
    • Once you take out the circuit board, you should be left with just the case.
  9. Canon Selphy CP910 Buttons Replacement: step 9, image 1 of 2 Canon Selphy CP910 Buttons Replacement: step 9, image 2 of 2
    • There is a clear plastic ā€œLā€ shaped piece that acts as the power light for the printer. The piece is not attached to the printer so take care not to lose it.
    • Remove the button framework and replace it with new one.
Christie Peralta
751 Reputation
5 Guides authored
UW Tacoma, Team 1-6, Rose Winter 2016 Member of UW Tacoma, Team 1-6, Rose Winter 2016
UWT-ROSE-W16S1G6
4 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 18
All Time: 1,056
