Canon Selphy CP910 LCD Screen Replacement
  1. Canon Selphy CP910 LCD Screen Replacement, Body: step 1, image 1 of 2 Canon Selphy CP910 LCD Screen Replacement, Body: step 1, image 2 of 2
    • Turn the printer over.
    • Use the PH1 screw bit to remove the three 8 mm screws in the middle of the back plate.
    • Keep track of these screws because you will need them to reassemble the printer.
  2. Canon Selphy CP910 LCD Screen Replacement: step 2, image 1 of 3 Canon Selphy CP910 LCD Screen Replacement: step 2, image 2 of 3 Canon Selphy CP910 LCD Screen Replacement: step 2, image 3 of 3
    • Loosen up the four 10 mm corner screws.
    • A screwdriver with a long shaft approximately 7mm in diameter will make it easier to reach these screws.
  3. Canon Selphy CP910 LCD Screen Replacement: step 3, image 1 of 3 Canon Selphy CP910 LCD Screen Replacement: step 3, image 2 of 3 Canon Selphy CP910 LCD Screen Replacement: step 3, image 3 of 3
    • Turn the device around and remove the "open" lid.
    • This lid needs to be removed in order to take the printer apart.
    • Gently bend the lid and remove it from its hinges.
  4. Canon Selphy CP910 LCD Screen Replacement: step 4, image 1 of 3 Canon Selphy CP910 LCD Screen Replacement: step 4, image 2 of 3 Canon Selphy CP910 LCD Screen Replacement: step 4, image 3 of 3
    • Turn the device back over and lift the top panel up.
    • Disconnect the ribbon cables leading to the LCD screen.
    • Pull the top panel off.
  5. Canon Selphy CP910 LCD Screen Replacement, LCD Screen: step 5, image 1 of 3 Canon Selphy CP910 LCD Screen Replacement, LCD Screen: step 5, image 2 of 3 Canon Selphy CP910 LCD Screen Replacement, LCD Screen: step 5, image 3 of 3
    • Once you detach the top, turn the device around.
    • Use the PH0 screw bit to remove the five [size] screws.
  6. Canon Selphy CP910 LCD Screen Replacement: step 6, image 1 of 3 Canon Selphy CP910 LCD Screen Replacement: step 6, image 2 of 3 Canon Selphy CP910 LCD Screen Replacement: step 6, image 3 of 3
    • Push out the LCD screen from the main case.
    • The screen should slide out freely.
  7. Canon Selphy CP910 LCD Screen Replacement: step 7, image 1 of 3 Canon Selphy CP910 LCD Screen Replacement: step 7, image 2 of 3 Canon Selphy CP910 LCD Screen Replacement: step 7, image 3 of 3
    • Pull out the rod connecting the LCD screen to the frame.
    • Insert the new screen.
Christie Peralta
751 Reputation
5 Guides authored
UW Tacoma, Team 1-6, Rose Winter 2016 Member of UW Tacoma, Team 1-6, Rose Winter 2016
UWT-ROSE-W16S1G6
4 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 21
All Time: 1,505
