Canon Selphy CP910 Printer Body Replacement
  1. Canon Selphy CP910 Printer Body Replacement, Body: step 1, image 1 of 2 Canon Selphy CP910 Printer Body Replacement, Body: step 1, image 2 of 2
    • Turn the printer over.
    • Use the PH1 screw bit to remove the three 8 mm screws in the middle of the back plate.
    • Keep track of these screws because you will need them to reassemble the printer.
  2. Canon Selphy CP910 Printer Body Replacement: step 2, image 1 of 3 Canon Selphy CP910 Printer Body Replacement: step 2, image 2 of 3 Canon Selphy CP910 Printer Body Replacement: step 2, image 3 of 3
    • Loosen up the four 10 mm corner screws.
    • A screwdriver with a long shaft approximately 7mm in diameter will make it easier to reach these screws.
  3. Canon Selphy CP910 Printer Body Replacement: step 3, image 1 of 3 Canon Selphy CP910 Printer Body Replacement: step 3, image 2 of 3 Canon Selphy CP910 Printer Body Replacement: step 3, image 3 of 3
    • Turn the device around and remove the "open" lid.
    • This lid needs to be removed in order to take the printer apart.
    • Gently bend the lid and remove it from its hinges.
  4. Canon Selphy CP910 Printer Body Replacement: step 4, image 1 of 3 Canon Selphy CP910 Printer Body Replacement: step 4, image 2 of 3 Canon Selphy CP910 Printer Body Replacement: step 4, image 3 of 3
    • Turn the device back over and lift the top panel up.
    • Disconnect the ribbon cables leading to the LCD screen.
    • Pull the top panel off.
  5. Canon Selphy CP910 Printer Body Replacement, Printer Body: step 5, image 1 of 2 Canon Selphy CP910 Printer Body Replacement, Printer Body: step 5, image 2 of 2
    • Use the PH1 screw driver to remove the three screws on the motherboard.
  6. Canon Selphy CP910 Printer Body Replacement: step 6, image 1 of 2 Canon Selphy CP910 Printer Body Replacement: step 6, image 2 of 2
    • Remove the printer.
    • This will prevent the printer from falling out during repair.
  7. Canon Selphy CP910 Printer Body Replacement: step 7, image 1 of 3 Canon Selphy CP910 Printer Body Replacement: step 7, image 2 of 3 Canon Selphy CP910 Printer Body Replacement: step 7, image 3 of 3
    • Remove the output connections.
    • Be careful! Do not pull too hard because the wires might rip.
    • Output connections are located on the corners of the motherboard.
  8. Canon Selphy CP910 Printer Body Replacement: step 8, image 1 of 2 Canon Selphy CP910 Printer Body Replacement: step 8, image 2 of 2
    • The motherboard is attached to three more ribbon wires.
    • Detach these wires.
    • Be careful not to pull too hard.
  9. Canon Selphy CP910 Printer Body Replacement: step 9, image 1 of 2 Canon Selphy CP910 Printer Body Replacement: step 9, image 2 of 2
    • Separate the motherboard from the main hard drive.
  10. Canon Selphy CP910 Printer Body Replacement: step 10, image 1 of 3 Canon Selphy CP910 Printer Body Replacement: step 10, image 2 of 3 Canon Selphy CP910 Printer Body Replacement: step 10, image 3 of 3
    • Remove the main hard drive from the printer body.
  11. Canon Selphy CP910 Printer Body Replacement: step 11, image 1 of 2 Canon Selphy CP910 Printer Body Replacement: step 11, image 2 of 2
    • Gently remove the fan from the body.
    • The fan is glued to the case. When you install it in the new body, use hot glue to secure it in place.
  12. Canon Selphy CP910 Printer Body Replacement: step 12, image 1 of 2 Canon Selphy CP910 Printer Body Replacement: step 12, image 2 of 2
    • The empty case will look like this once all the parts are removed.
2 other people completed this guide.
Christie Peralta
712 Reputation
5 Guides authored
UW Tacoma, Team 1-6, Rose Winter 2016 Member of UW Tacoma, Team 1-6, Rose Winter 2016
UWT-ROSE-W16S1G6
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 66
All Time: 4,963
