Canon Vixia HF R600 Camera Lens Replacement
  1. Canon Vixia HF R600 Camera Lens Replacement, Handstrap: step 1, image 1 of 2 Canon Vixia HF R600 Camera Lens Replacement, Handstrap: step 1, image 2 of 2
    • Pull up the Velcro strap starting from the front of the camera and working your way towards the back.
    • If you are adjusting the hand-strap, tighten or loosen the Velcro strap accordingly and reattach it.
    • To remove the hand-strap, pull the Velcro strip through the leather pad.
  2. Canon Vixia HF R600 Camera Lens Replacement: step 2, image 1 of 2 Canon Vixia HF R600 Camera Lens Replacement: step 2, image 2 of 2
    • Remove the strap from the camera body.
  3. Canon Vixia HF R600 Camera Lens Replacement, Battery: step 3, image 1 of 2 Canon Vixia HF R600 Camera Lens Replacement, Battery: step 3, image 2 of 2
    • Press in the battery release tab located on the bottom of the camera.
    • Slide the battery out from the body.
  4. Canon Vixia HF R600 Camera Lens Replacement, Casing: step 4, image 1 of 2 Canon Vixia HF R600 Camera Lens Replacement, Casing: step 4, image 2 of 2
    • Start by removing the two 6mm Phillips #00 screws located on the right side of the camera.
    • Remove four more 6mm Phillips #00 screws found on the bottom of the camera.
  5. Canon Vixia HF R600 Camera Lens Replacement: step 5, image 1 of 2 Canon Vixia HF R600 Camera Lens Replacement: step 5, image 2 of 2
    • Open the display screen and remove the three 5mm Phillips #00 screws.
    • Look to the swivel point for the screen to find the last two 5mm Phillips #00 screws that must be removed.
  6. Canon Vixia HF R600 Camera Lens Replacement: step 6, image 1 of 2 Canon Vixia HF R600 Camera Lens Replacement: step 6, image 2 of 2
    • Gently pull the plastic casing away from the camera.
  7. Canon Vixia HF R600 Camera Lens Replacement, Camera Lens: step 7, image 1 of 3 Canon Vixia HF R600 Camera Lens Replacement, Camera Lens: step 7, image 2 of 3 Canon Vixia HF R600 Camera Lens Replacement, Camera Lens: step 7, image 3 of 3
    • Remove one 5mm Phillips PH#00 screw from the top of the camera.
    • Pull away the plastic shutter casing; this contains the microphone.
    • Using the plastic opening tool or something similar, carefully disconnect the white 4 pin connector to remove the shutter casing.
  8. Canon Vixia HF R600 Camera Lens Replacement: step 8, image 1 of 2 Canon Vixia HF R600 Camera Lens Replacement: step 8, image 2 of 2
    • Remove the three 5mm Phillips PH#00 screws surrounding the camera lens.
    • Pull the lens off of the camera and replace.
2 other people completed this guide.
Brian Luna
483 Reputation
4 Guides authored
USF Tampa, Team 14-4, Lacy Spring 2016 Member of USF Tampa, Team 14-4, Lacy Spring 2016
USFT-LACY-S16S14G4
3 Members
16 Guides authored
One Comment
I think you need a part, the lens..... Which is what I also need, which is why I'm here..... Now, if I could just figure out where to get a lens your tutorial would be helpful.
dannyknappy - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 632
