Canon Vixia HF R62 Central Capturing Unit Replacement
  1. Canon Vixia HF R62 Central Capturing Unit Replacement, Outer Shell: step 1, image 1 of 2 Canon Vixia HF R62 Central Capturing Unit Replacement, Outer Shell: step 1, image 2 of 2
    • Remove the strap by undoing the Velcro and pulling it through the thread points.
    • Remove the external battery pack by pressing down on the slide release and sliding it out.
  2. Canon Vixia HF R62 Central Capturing Unit Replacement: step 2, image 1 of 2 Canon Vixia HF R62 Central Capturing Unit Replacement: step 2, image 2 of 2
    • Remove the three 5mm Phillips #000 screws on the bottom of the device.
  3. Canon Vixia HF R62 Central Capturing Unit Replacement: step 3, image 1 of 2 Canon Vixia HF R62 Central Capturing Unit Replacement: step 3, image 2 of 2
    • On the side of the device, remove the following Phillips #000 screws:
    • One 3mm screw
    • One 5mm screw
  4. Canon Vixia HF R62 Central Capturing Unit Replacement: step 4, image 1 of 2 Canon Vixia HF R62 Central Capturing Unit Replacement: step 4, image 2 of 2
    • Remove the panel opposite the display by pulling up perpendicular to the side.
  5. Canon Vixia HF R62 Central Capturing Unit Replacement: step 5, image 1 of 1
    • Remove the 4mm Phillips #000 screw that was exposed after taking off the side panel.
  6. Canon Vixia HF R62 Central Capturing Unit Replacement: step 6, image 1 of 2 Canon Vixia HF R62 Central Capturing Unit Replacement: step 6, image 2 of 2
    • Remove the three 4mm Phillips #000 screws shown.
    • There will be foam covers protecting some or all of these screws. These will need to be removed before you will be able to unscrew them.
  7. Canon Vixia HF R62 Central Capturing Unit Replacement: step 7, image 1 of 3 Canon Vixia HF R62 Central Capturing Unit Replacement: step 7, image 2 of 3 Canon Vixia HF R62 Central Capturing Unit Replacement: step 7, image 3 of 3
    Tool used on this step:
    Buy
    • Using tweezers, disconnect this ribbon cable by pulling straight out.
  8. Canon Vixia HF R62 Central Capturing Unit Replacement: step 8, image 1 of 3 Canon Vixia HF R62 Central Capturing Unit Replacement: step 8, image 2 of 3 Canon Vixia HF R62 Central Capturing Unit Replacement: step 8, image 3 of 3
    • Repeat step seven (7) for the remaining three wires shown.
  9. Canon Vixia HF R62 Central Capturing Unit Replacement: step 9, image 1 of 3 Canon Vixia HF R62 Central Capturing Unit Replacement: step 9, image 2 of 3 Canon Vixia HF R62 Central Capturing Unit Replacement: step 9, image 3 of 3
    • Grasp the top of the camera and pull straight up to remove the top panel.
  10. Canon Vixia HF R62 Central Capturing Unit Replacement, Lens: step 10, image 1 of 1
    • Remove the 5mm Phillips #000 screw on top of the inner case.
  11. Canon Vixia HF R62 Central Capturing Unit Replacement: step 11, image 1 of 2 Canon Vixia HF R62 Central Capturing Unit Replacement: step 11, image 2 of 2
    • Remove the two 5mm Phillips #000 screws near the display panel.
  12. Canon Vixia HF R62 Central Capturing Unit Replacement: step 12, image 1 of 2 Canon Vixia HF R62 Central Capturing Unit Replacement: step 12, image 2 of 2
    • Disconnect the small bundled cable connector on the side of the lens cover by pulling it straight out.
  13. Canon Vixia HF R62 Central Capturing Unit Replacement: step 13, image 1 of 2 Canon Vixia HF R62 Central Capturing Unit Replacement: step 13, image 2 of 2
    • Remove the lens cover by pulling straight away from the body.
  14. Canon Vixia HF R62 Central Capturing Unit Replacement: step 14, image 1 of 2 Canon Vixia HF R62 Central Capturing Unit Replacement: step 14, image 2 of 2
    • Remove the three 6mm Phillips #000 screws shown.
  15. Canon Vixia HF R62 Central Capturing Unit Replacement: step 15, image 1 of 2 Canon Vixia HF R62 Central Capturing Unit Replacement: step 15, image 2 of 2
    • Remove the lens by pulling straight away from the main body.
    • Be aware of the small rubber gasket around the lens as it may come loose.
  16. Canon Vixia HF R62 Central Capturing Unit Replacement, Internal Battery and SD Card Reader: step 16, image 1 of 3 Canon Vixia HF R62 Central Capturing Unit Replacement, Internal Battery and SD Card Reader: step 16, image 2 of 3 Canon Vixia HF R62 Central Capturing Unit Replacement, Internal Battery and SD Card Reader: step 16, image 3 of 3
    • Remove the two 3mm Phillips #000 screws.
    • Remove the 4mm Phillips #000 screw.
  17. Canon Vixia HF R62 Central Capturing Unit Replacement: step 17, image 1 of 2 Canon Vixia HF R62 Central Capturing Unit Replacement: step 17, image 2 of 2
    • Disconnect the ribbon cable shown.
  18. Canon Vixia HF R62 Central Capturing Unit Replacement: step 18, image 1 of 1
    • Remove the 4mm Phillips #000 screw at the bottom of the camera.
  19. Canon Vixia HF R62 Central Capturing Unit Replacement: step 19, image 1 of 3 Canon Vixia HF R62 Central Capturing Unit Replacement: step 19, image 2 of 3 Canon Vixia HF R62 Central Capturing Unit Replacement: step 19, image 3 of 3
    • Place the spudger under the tab shown.
    • While prying the tab up with the spudger, pull the case away.
  20. Canon Vixia HF R62 Central Capturing Unit Replacement, Central Capturing Unit: step 20, image 1 of 3 Canon Vixia HF R62 Central Capturing Unit Replacement, Central Capturing Unit: step 20, image 2 of 3 Canon Vixia HF R62 Central Capturing Unit Replacement, Central Capturing Unit: step 20, image 3 of 3
    • Using a spudger, disconnect the ribbon cable connector from the PC board shown in the picture.
  21. Canon Vixia HF R62 Central Capturing Unit Replacement: step 21, image 1 of 2 Canon Vixia HF R62 Central Capturing Unit Replacement: step 21, image 2 of 2
    Buy
    • Using tweezers, disconnect the ribbon cable shown in the picture by pulling straight out.
  22. Canon Vixia HF R62 Central Capturing Unit Replacement: step 22, image 1 of 3 Canon Vixia HF R62 Central Capturing Unit Replacement: step 22, image 2 of 3 Canon Vixia HF R62 Central Capturing Unit Replacement: step 22, image 3 of 3
    • Using a spudger, gently pry up the top tab on the ZIF connector. The wire will now disconnect with no force needed.
    • When reassembling you will need to place the ribbon wire tightly against the tab in order to properly secure it.
  23. Canon Vixia HF R62 Central Capturing Unit Replacement: step 23, image 1 of 3 Canon Vixia HF R62 Central Capturing Unit Replacement: step 23, image 2 of 3 Canon Vixia HF R62 Central Capturing Unit Replacement: step 23, image 3 of 3
    • Using your fingers, firmly grasp both ends of the capturing device and gently pull the assembly straight out.
To reassemble the central capturing unit, follow these instructions in reverse order.
One Comment
thank you for helping me and i am really grateful for your assistance.
PATRICK ANIM - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 177
