Canon Vixia HF R70 Side Panel Replacement
  1. Canon Vixia HF R70 Side Panel Replacement, Battery: step 1, image 1 of 1
    • Power off and unplug the device.
    • Position the camera so that the battery is facing you.
  2. Canon Vixia HF R70 Side Panel Replacement: step 2, image 1 of 1
    • Locate the latch on the bottom edge of the camera.
    • Hold the battery into place and gently push down on the latch towards the lens.
  3. Canon Vixia HF R70 Side Panel Replacement: step 3, image 1 of 2 Canon Vixia HF R70 Side Panel Replacement: step 3, image 2 of 2
    • While holding down the latch, remove the battery by pulling it out of the device.
  4. Canon Vixia HF R70 Side Panel Replacement, Wrist Strap: step 4, image 1 of 1
    • Position the camcorder so that the wrist strap is facing you.
    • Locate the loose end of the strap.
  5. Canon Vixia HF R70 Side Panel Replacement: step 5, image 1 of 1
    • Gently pull on the loose end to separate the Velcro.
  6. Canon Vixia HF R70 Side Panel Replacement: step 6, image 1 of 1
    • Locate the "slot" on bottom right corner of the camcorder where the strap loops through.
    • Pull the strap through the loop.
  7. Canon Vixia HF R70 Side Panel Replacement: step 7, image 1 of 2 Canon Vixia HF R70 Side Panel Replacement: step 7, image 2 of 2
    • Pull the strap through the leather cushion.
  8. Canon Vixia HF R70 Side Panel Replacement: step 8, image 1 of 1
    • Pull the strap through the slot on the left side of the camcorder.
  9. Canon Vixia HF R70 Side Panel Replacement, Side Panel: step 9, image 1 of 2 Canon Vixia HF R70 Side Panel Replacement, Side Panel: step 9, image 2 of 2
    • Position the camcorder so that the side panel is facing you.
    • Locate the two 6mm Phillips #00 screws on the side panel.
    • Remove the the screws using a screwdriver with a Phillips #00 head.
  10. Canon Vixia HF R70 Side Panel Replacement: step 10, image 1 of 3 Canon Vixia HF R70 Side Panel Replacement: step 10, image 2 of 3 Canon Vixia HF R70 Side Panel Replacement: step 10, image 3 of 3
    • Turn the camcorder so that the bottom is facing you.
    • Using your screwdriver, locate and remove the four 6mm Phillips #00 screws connecting the side panel to the bottom of the camcorder.
  11. Canon Vixia HF R70 Side Panel Replacement: step 11, image 1 of 2 Canon Vixia HF R70 Side Panel Replacement: step 11, image 2 of 2
    • Gently remove the side panel by pushing it up from the bottom.
Thomas Rogienski
501 Reputation
5 Guides authored
USF Tampa, Team S2-G2, Nance Spring 2017 Member of USF Tampa, Team S2-G2, Nance Spring 2017
USFT-NANCE-S17S2G2
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 424
