Canon ZR70MC Speaker Replacement
  1. Canon ZR70MC Speaker Replacement, Front Panel: step 1, image 1 of 2 Canon ZR70MC Speaker Replacement, Front Panel: step 1, image 2 of 2
    • Unscrew the 3.35mm screw.
  2. Canon ZR70MC Speaker Replacement: step 2, image 1 of 1
    • Turn the ZR70MC so that you can see the bottom of the camcorder.
    • Unscrew the 3.35 mm located in the top left portion of the camera.
  3. Canon ZR70MC Speaker Replacement: step 3, image 1 of 3 Canon ZR70MC Speaker Replacement: step 3, image 2 of 3 Canon ZR70MC Speaker Replacement: step 3, image 3 of 3
    • Turn the camera on the side and remove the cover for the audio inputs. There is a 2.65 mm screw located behind the cover.
    • Remove the 2.65 mm screw.
  4. Canon ZR70MC Speaker Replacement: step 4, image 1 of 3 Canon ZR70MC Speaker Replacement: step 4, image 2 of 3 Canon ZR70MC Speaker Replacement: step 4, image 3 of 3
    • Remove the cover located on the front of the camcorder and remove the cover by pulling on the bottom groove.
    • Locate and remove the two 3.35 mm screws.
  5. Canon ZR70MC Speaker Replacement: step 5, image 1 of 2 Canon ZR70MC Speaker Replacement: step 5, image 2 of 2
    • Turn the camcorder so that the bottom is facing up and open the tape cassette compartment.
    • There is one 3.35 mm screw located under the tape cassette panel on the front left side of the camcorder. Remove the screw.
  6. Canon ZR70MC Speaker Replacement: step 6, image 1 of 3 Canon ZR70MC Speaker Replacement: step 6, image 2 of 3 Canon ZR70MC Speaker Replacement: step 6, image 3 of 3
    • Now that all of the screws are removed, remove the front panel by gently pulling on the front panel.
    • The speaker will be connected to the main body by a wire. Be careful not to damage this wire.
  7. Canon ZR70MC Speaker Replacement: step 7, image 1 of 3 Canon ZR70MC Speaker Replacement: step 7, image 2 of 3 Canon ZR70MC Speaker Replacement: step 7, image 3 of 3
    Tool used on this step:
    Buy
    • Use tweezers to gently pull the speaker wire from the main body of the camcorder.
    • Pull the front panel completely away from the main body of the camcorder.
  8. Canon ZR70MC Speaker Replacement, Speaker: step 8, image 1 of 3 Canon ZR70MC Speaker Replacement, Speaker: step 8, image 2 of 3 Canon ZR70MC Speaker Replacement, Speaker: step 8, image 3 of 3
    • Take the front panel and remove the three 2.75 mm screws from the metal plate.
  9. Canon ZR70MC Speaker Replacement: step 9, image 1 of 3 Canon ZR70MC Speaker Replacement: step 9, image 2 of 3 Canon ZR70MC Speaker Replacement: step 9, image 3 of 3
    • Remove the metal plate. This metal plate protects the black speaker holder.
  10. Canon ZR70MC Speaker Replacement: step 10, image 1 of 3 Canon ZR70MC Speaker Replacement: step 10, image 2 of 3 Canon ZR70MC Speaker Replacement: step 10, image 3 of 3
    • Remove the black speaker holder from the front panel. This holds the individual speakers.
  11. Canon ZR70MC Speaker Replacement: step 11, image 1 of 3 Canon ZR70MC Speaker Replacement: step 11, image 2 of 3 Canon ZR70MC Speaker Replacement: step 11, image 3 of 3
    • Remove the individual speakers from the black speaker holder.
khalid clarke
824 Reputation
7 Guides authored
USF Tampa, Team S13-G2, Boczar Fall 2017 Member of USF Tampa, Team S13-G2, Boczar Fall 2017
USFT-BOCZAR-F17S13G2
3 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 137
