Capresso Infinity Outside Casing Replacement
  1. Capresso Infinity Outside Casing Replacement, Metal Outside Casing: step 1, image 1 of 2 Capresso Infinity Outside Casing Replacement, Metal Outside Casing: step 1, image 2 of 2
    • Twist the top plastic container to the left counterclockwise.
    • Pull upwards to remove.
  2. Capresso Infinity Outside Casing Replacement: step 2, image 1 of 3 Capresso Infinity Outside Casing Replacement: step 2, image 2 of 3 Capresso Infinity Outside Casing Replacement: step 2, image 3 of 3
    • Twist the top burr to the left counter clockwise.
  3. Capresso Infinity Outside Casing Replacement: step 3, image 1 of 2 Capresso Infinity Outside Casing Replacement: step 3, image 2 of 2
    • Flip entire device upside down.
    • Remove two rubber coverings on the back of the device.
  4. Capresso Infinity Outside Casing Replacement: step 4, image 1 of 2 Capresso Infinity Outside Casing Replacement: step 4, image 2 of 2
    • Remove four 11.59mm T10 screws.
    • The screws will have small circular washers under them. Put them aside for reassembly.
  5. Capresso Infinity Outside Casing Replacement: step 5, image 1 of 3 Capresso Infinity Outside Casing Replacement: step 5, image 2 of 3 Capresso Infinity Outside Casing Replacement: step 5, image 3 of 3
    • Lift the metal outside casing off the black base.
    • Flip the outside casing forward so you have access to the inside of it.
  6. Capresso Infinity Outside Casing Replacement: step 6, image 1 of 3 Capresso Infinity Outside Casing Replacement: step 6, image 2 of 3 Capresso Infinity Outside Casing Replacement: step 6, image 3 of 3
    • Remove one 11.59mm T10 screw.
    • Let the green wire fall, or place somewhere so it doesn't get in the way.
    • There will be a small metal retainer and washer, put them aside for reassembly.
  7. Capresso Infinity Outside Casing Replacement: step 7, image 1 of 3 Capresso Infinity Outside Casing Replacement: step 7, image 2 of 3 Capresso Infinity Outside Casing Replacement: step 7, image 3 of 3
    • Remove two 11.59mm T10 screws.
  8. Capresso Infinity Outside Casing Replacement: step 8, image 1 of 2 Capresso Infinity Outside Casing Replacement: step 8, image 2 of 2
    • Remove the time/on switch by pulling upwards.
Nina Mackin
528 Reputation
2 Guides authored
USF Tampa, Team S1-G1, Leahy Fall 2018 Member of USF Tampa, Team S1-G1, Leahy Fall 2018
USFT-LEAHY-F18S1G1
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 17
All Time: 1,465
