Capresso Infinity Timer/On Switch Replacement
  1. Capresso Infinity Timer/On Switch Replacement, Metal Outside Casing: step 1, image 1 of 2 Capresso Infinity Timer/On Switch Replacement, Metal Outside Casing: step 1, image 2 of 2
    • Twist the top plastic container to the left counterclockwise.
    • Pull upwards to remove.
  2. Capresso Infinity Timer/On Switch Replacement: step 2, image 1 of 3 Capresso Infinity Timer/On Switch Replacement: step 2, image 2 of 3 Capresso Infinity Timer/On Switch Replacement: step 2, image 3 of 3
    • Twist the top burr to the left counter clockwise.
  3. Capresso Infinity Timer/On Switch Replacement: step 3, image 1 of 2 Capresso Infinity Timer/On Switch Replacement: step 3, image 2 of 2
    • Flip entire device upside down.
    • Remove two rubber coverings on the back of the device.
  4. Capresso Infinity Timer/On Switch Replacement: step 4, image 1 of 2 Capresso Infinity Timer/On Switch Replacement: step 4, image 2 of 2
    • Remove four 11.59mm T10 screws.
    • The screws will have small circular washers under them. Put them aside for reassembly.
  5. Capresso Infinity Timer/On Switch Replacement: step 5, image 1 of 3 Capresso Infinity Timer/On Switch Replacement: step 5, image 2 of 3 Capresso Infinity Timer/On Switch Replacement: step 5, image 3 of 3
    • Lift the metal outside casing off the black base.
    • Flip the outside casing forward so you have access to the inside of it.
  6. Capresso Infinity Timer/On Switch Replacement: step 6, image 1 of 3 Capresso Infinity Timer/On Switch Replacement: step 6, image 2 of 3 Capresso Infinity Timer/On Switch Replacement: step 6, image 3 of 3
    • Remove one 11.59mm T10 screw.
    • Let the green wire fall, or place somewhere so it doesn't get in the way.
    • There will be a small metal retainer and washer, put them aside for reassembly.
  7. Capresso Infinity Timer/On Switch Replacement: step 7, image 1 of 3 Capresso Infinity Timer/On Switch Replacement: step 7, image 2 of 3 Capresso Infinity Timer/On Switch Replacement: step 7, image 3 of 3
    • Remove two 11.59mm T10 screws.
  8. Capresso Infinity Timer/On Switch Replacement: step 8, image 1 of 2 Capresso Infinity Timer/On Switch Replacement: step 8, image 2 of 2
    • Remove the time/on switch by pulling upwards.
  9. Capresso Infinity Timer/On Switch Replacement, Timer/On Switch: step 9, image 1 of 1
    • Strip the two wires of their black covering connecting them to the black box.
  10. Capresso Infinity Timer/On Switch Replacement: step 10, image 1 of 3 Capresso Infinity Timer/On Switch Replacement: step 10, image 2 of 3 Capresso Infinity Timer/On Switch Replacement: step 10, image 3 of 3
    • Solder the two cords holding in the blue and white wire in the black timer box.
3 other people completed this guide.
Melayne Spataro
272 Reputation
1 Guide authored
USF Tampa, Team S1-G1, Leahy Fall 2018 Member of USF Tampa, Team S1-G1, Leahy Fall 2018
USFT-LEAHY-F18S1G1
4 Members
5 Guides authored
7 Comments
do you know where I can get a new black timer box?
geclay@hotmail.com - Reply
Where can I purchase a timer/on switch?
Rob Gordon - Reply
Same question here, where can I buy this part?
Dominic Daigle - Reply
Just piling on,has anyone found where to buy the Timer switch?
Chris DiNicolas - Reply
Same, looking for part number and/or where to buy the timer dial.
Hans Sorensen - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 43
All Time: 2,468
